1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2007 f350 4x4 problem
Old 02-03-2015, 05:43 PM
fastcarz3's Avatar
fastcarz3
fastcarz3 is offline
hi guys i have an 07 350 6.0 was plowing last night toward the end of the night i herd a popping coming off the front end of the truck mind u my esof does not work so i manually lock the hubs and then turn on the 4x4 from the dash when i want 4x4, ok so after the few pops i herd while slightly turning i straighened out and all seem ok till i pulled outta the parking lot started driving and i had a noise kinda sounded like driving on a flat while at speeds at around 25-35mph so i got out unlocked the hubs drove it and it drives fine unlocked. so what I've done so far is while hubs unlocked climbed under it spun the front driveshaft by hand and spins freely. when the truck is rolling with no issues i locked the hubs left the switch in 2wd turned the wheel and started to make a turn and POP loud and shakes the truck violently it feel likes the steering and the truck is binding when trying to turn. can anyone help shed some light on my problem
Old 02-03-2015, 06:16 PM
fastcarz3's Avatar
fastcarz3
I just took the truck up the corner to get milk and now for some reason I can't turn the wheel to the left
Old 02-04-2015, 07:54 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
sorry for your woes
I didnt think you could lock the axles on pavement...I thought it would bind on turns.
folks keep talking about locking the axles during the winter so they do not have to get out to manually lock the axles.....I'm not understanding how thats possible on pavement with out binding.
Old 02-04-2015, 10:40 PM
jetjockey99's Avatar
jetjockey99
jetjockey99 is offline
sounds like the steering knuckle u-joints are binding up.
Old 02-05-2015, 07:15 AM
fastcarz3's Avatar
fastcarz3
Hey just an update took some things apart and found a bad U joint and a broken axle hense why I couldnt turn Id post a pic but can't figure out how
Vinford
10-24-2012 09:10 PM
akuhr93'f150
04-01-2012 10:26 PM
nut1605
07-28-2007 01:10 AM
jjohn82
03-03-2005 09:37 PM
medicone67
02-15-2003 08:54 PM
Quick Reply: 2007 f350 4x4 problem
