breather, riser ID sought
Cannot find any part numbers on these items I purchased on Ebay a while back. They are not what I thought - for a 240/300 - when I purchased them (chalk up another for wasted bucks on useless parts). I am guessing they are for a 360 or the like.
Can anyone tell from the pictures what this assembly came off of?
Left: 1968/69 F100/350 240/300. The metal tube (9652) is a separate part, not furnished with the 9A603 pre heat shroud.
Right (upper): 1970/72 F100/350 240/300. 9652 is a "cut to fit" flexible corrugated paper hose that is available from auto parts stores, as it also was used on myriad cars.
Well the shape does not match up with what I have in my 69. The lower portion did not match up. I was looking for something to use on my 71 when I bought it. Right now have a 2-inch sleeve welded to the exhaust manifold and a flex tube riser.
Additionally, the mouth on the bottom side of the breather that connects to the riser is bigger than my 69's.
Will have to revisit it.
Basically, I was in the process of trying to find a new home for the part.
I don't think the part that attaches to the manifold underneath the carb will work on our 240/300 engines. But will take a look again.
When I get home this evening - if I don't drive to Bandera to pick up a Walther PP .32 cal - I will check on the measurements and re-compare it to my setup on my 69.
Pickupmanx2
31
05-06-2019 11:24 AM
Col Flashman
12-11-2018 03:06 AM
CharlieXLT
18
09-06-2018 02:47 PM
65 Econoline
Vehicles for Sale
02-07-2016 12:05 AM
