240 or 300?
Old May 2, 2010 | 08:56 PM
Boo-Boo's Avatar
Boo-Boo
240 or 300?
My 1966 F100 has a 1975 inline 6. But I'm not sure if it's a 240 or 300 and I don't see any obvious way to tell. Any suggestions?
Old May 2, 2010 | 09:11 PM
BadCo_67's Avatar
BadCo_67
If the original valve-cover decal is still there, you can decode it here:
1973-1979 Ford Truck Engine ID Tag Codes - FORDification.net
Old May 2, 2010 | 10:07 PM
Tees77f150's Avatar
Tees77f150
Here is a couple of pictures of my 1977 300 I6 for comparison, if that helps.
Bore, stroke, or valve size would be different.
Old May 3, 2010 | 06:52 AM
Boo-Boo's Avatar
Boo-Boo
Thanks Guys. Got no valve cover decal, but all the same it was nice to see Tee's engine. It's a beauty.
Old May 3, 2010 | 07:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If you are sure the I-6 is from a 1975, and the engine was original to that truck, it's a 300 I-6.
The 240 was canceled after the 1974 model year ended.
If you are not sure, you have to measure the stroke to tell the difference between the 240 & 300, since both use the same block and look identical.
Stroke: 240 = 3.18" / 300 = 3.98"
Old May 3, 2010 | 05:37 PM
Richards73's Avatar
Richards73
what would we do without numberDummy
Old May 3, 2010 | 08:25 PM
adamtheman16's Avatar
adamtheman16
kentruckf100
Aug 20, 2015 10:33 AM
boos65
Jun 26, 2012 04:49 PM
Comsense
Dec 7, 2011 02:53 PM
murraydav
1997 - 2003 F150
Nov 27, 2011 02:44 AM
RexB
Washington Chapter
20
Mar 8, 2007 11:10 PM
