Help identifying this part
Old 01-31-2015, 08:48 AM
Florida 350's Avatar
Florida 350
Florida 350 is offline
Can someone please help me with what this is?
The sensor or whatever on the top rear of the block right behind intake with the plug coming out of the white part.
Trying to find a replacement for it but not sure what it is.
Thanks.
Old 01-31-2015, 10:57 PM
Torky2's Avatar
Torky2
Torky2 is offline
Well, your description is confusing to me, at least...
The FRONT of the engine is to the right in the pic, so the rear of the block is to the LEFT. So the only sensor I see on the top REAR of the block is Yellow, and probably is the oil pressure switch.
Around towards the front of the engine, I see a white sensor on top of an intake runner, that could be an IAT (Intake Air Temperature) sensor.
And further forward, another sensor that is White or Gray, if it is into a water crossover, then I would expect it to be an ECT (Engine Coolant Temperature) sensor.
And further forward, and a bit lower down, not far from the water outlet area, is a single-wire sensor, probably the coolant temperature sensor for the temp gauge.
But that's all the sensors I see, unless there is a hidden sensor that I am unable to see in the pic, like a Where's Waldo sensor
Old 02-01-2015, 07:25 AM
Florida 350
yeah i figured it out finally. good to go
MelvilArnt
13
11-02-2016 02:27 PM
mlb5000
06-18-2010 04:08 PM
old hog hauler
12-12-2007 10:18 PM
dsheleg
02-17-2005 09:20 PM
Quick Reply: Help identifying this part
