Vehicle maintence schedule
I just thought it would be handy to have a thread on here related to the maintence schedules of our rigs! I'll post what would need to be done to these pick-ups. I'll update it with peoples updates.
Engine oil- every 3000 miles
Motorcraft 820s filter and your choice of oil (I run 15-40 diesel oil because it's cheaper and it has more detergents)
Antifreeze- at least once a year
50/50 mix or distiled water and antifreeze
Spark plugs- every ? Miles
Motorcraft or autolite copper plugs
Cap and rotor- every ? Miles
I run MSD for these
Plug wires- every ? Miles
I run Ford racing 9mm wires
Coil- every ? Miles
I'll run a motorcraft or MSD
Air filter- every other oil change
I run wix or motorcraft
Transmission fluid- every 10-15,000 Miles
I'll run a good synthetic
Tranny filter- every ? Miles
Motorcraft or comparable filter
Differential fluid- every ? Miles
Fully synthetic 75-90 I believe with friction modifier for limited slip diffs
Wheel bearings- every ? Miles or whenever they wear out
I run Timken or of equal quality
Brakes- whenever they need it
Ball joints- whenever they wear out
Tie-rods- whenever they need it
If there's anything I missed please comment and I'll add to it! I think this would be a good thread for a sticky!
I run MSD for these
Coil- every ? Miles
Here my list of mantince
Oil change- every 3000 miles
Shell o rotella 15w40 diesel oil
Spark plugs,wires,cap,rotor- once a year with mad cap and rotor,ford racing 8mm wires and motorcraft platinum plugs
Front and rear diffs- every 5000 or so miles I mud a lots so want to get any water out if its in there
Trans I have a e4od I just did a cooler flush -filter and fluid change I try to Chang the fluid every 10,000 miles
Wheel bearings- check and re pack once a year replace if need be
Air filter- I have a k&n I clean out when ever it looks dirty
Other then that I haven't done breaks I'm about a year I just used the top of the line Napa gold pads and rotors drums and shoes last time around,I like to pull out a can of pb blaster every oil change and spray up all the hinges and latches ect
I do oil every 4000 miles or so with how far I drive my truck allot of times and I tend to do plugs and wires every year or so.
Diff and tranny fluid I've done once and do not feel that they need to be changed for at least another two years. I just keep an eye on the level of it.
Coolant I try to do every two to three years even if its just a partial flush.
Oh also to not I've been running synthetic 5w-30 motor oil with Lucas oil stabilizer and have been having good luck with it so far, just wish the crap wasn't so expensive, may end up just going to rottela brand 15w-40 this spring and seeing how it likes that. Cause if she likes it I'll keep it in the pan tell it gets pulled for a 351w.
Johnny Langton
02-09-2010 12:44 PM
