stock horn removed- replacement?
My horn hasnt worked so i started to investigate. The relay is good as well as fuse. Does the horn have a wire hatness with connnector? I found a connnector hanging right in front of passenger front tire behind the bumper. Not sure what it goes to.
I cant seem to find a part # for an oem replacement. Should i just go aftermarket? If so, any suggestions non a horn? I want one that has a deep loud tone.
On another note, my light under the hood is not working. I check and its on same fuse as horn. I put new lamp in and nothing.
