2002 F-150 sudden fuel mileage drop
Hey I'm new to posting to the forums but here goes nothing. I recently changed the fuel pump on my 02 F-150 (4.6 V8) with much guidance from these forums. The truck was getting to where it would not start right away. It would crank and crank but wouldn't fire. I replaced the pump and it fixed that issue. Now the fuel mileage has decreased significantly (4-5 mpg). Do I need to have the computer reset or any other ideas on what could cause this?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
When I changed mine I was warned that the sending unit was redesigned so it was more accurate in mid and low range. I used to be able to top off the tank and drive 50 miles before gage moved now it starts moving after 20. Might this be what you are seeing? My actual checked mileage has not changed.
I do not have a way of testing the pressures, unfortunately. The check engine light has never come on. I took the truck to a mechanic prior to changing the pump and his code reader did not come up with anything. Could I pull one of the spark plugs and made a judgement there?
Hard to tell looking at plugs if there is no black exhaust smoke.
High fuel pressure can cause a rich condition.
Since the fuel mileage dropped right after installing a new fuel pump,high
pressure could be suspect.
It only takes a shop a few minutes to check it to confirm
the pressures are within spec.
While I was there, I would get it scanned for pending codes as well that
are stored but not yet lighting the CEL.
Good luck
keep us posted
Good luck
keep us posted
Good luck
keep us posted
I was thinking maybe the old pump was weak with a poor regulator,
install a new pump with the same regulator maybe =high pressure?
I think the regulator should be by #7 cylinder on this generation Steve?
