302 electrical issues
I have a 1990 f250 with a 302. I did a lower intake job and when I put it back together I had no spark. I removed the spout and then I had spark. After removing the spout it still wouldn't start so I removed a spark plug and it was dry so im assuming the injectors arnt firing. The fuel pump does cycle. The ecm relay does click when the key is turned on. I have put another ecm in it and it still has the same issues. Is there something that I could've left unconnected? I checked the fusible links and none of them stretch. Any ideas?
I went out and looked and I couldn't get eye level enough with distributor to see all 6 pins, but I looked and the connector and the very top slot has a gouge right next to the connector slot like the pin got bent back. I looked up a diagram and the top pin is the pip so it makes sense right?
Thanks for mentioning that I went out and used my camera and put it in the distributer plugin and sure enough, pip pin is bent straight back
88XLTLariat
02-14-2017 08:32 PM
OceansideAirbrush
12-01-2016 08:46 AM
nnewman
06-01-2009 04:55 PM
