pros and cons of flatbeds
Sorry I haven't posted in a while I've been extremely busy and have had next to no time to work on my truck unless something needed to be done since ALL of my time and money is currently going into the farm. So I'm trying to get back into posting on here and I hate to come back and just ask questions but it is what it is I suppose.
Now back to the question: I'm considering making a flatbed for my truck (1987 f150) or the farm truck (1982 f350). I wanted to know what the pros and cons of a flatbed are and if a flatbed is better than a pickup bed? I am more likely to be making one for the farm truck since it has a rotted out dump bed on it and it's an f350 And I'm considering doing a SRW swap instead of keeping The dual wheels. Thoughts about this? Any help is appreciated as usual
on
A flatbed is real useful for loading things with a tractor or forklift from the side, but an old F150 doesn't have a high enough cargo capacity to really justify a flatbed.. basically if you need a tractor to lift it it's too heavy for the 1/2 ton so I'd suggest putting the flatbed on the F350.
Another thing to consider about a flat bed... you need to tie EVERYTHING down you put on it.
A flatbed ia at least 6" higher than a standard pickup bed, so you have to pick thing HIGHER to put them on the flat bed.
Flatbeds weight MORE than pickup beds, so that limits how much you can put on them.
Also figure resale. MOST people do Not want a flatbed
Agreed.
Agreed.
Picking things up higher isn't much of a problem unless I use it to haul hay then I just have to throw it higher. How much would it limit the f350's carrying capacity if it was an all steel flatbed? Tying things down isn't a problem either other than it would get pretty annoying I'm sure. And why do not many people want a flatbed?
A sheet metal pickup bed weights about 300lbs. And all metal flatbed weights about 1000lbs. That that limits your weight capacity by about 700lbs
For all the reasons I listed is why people don't want them.
Most people who want them (A) have never used one, (B) Want one because they look cool. (C) they don't use their truck to begin with so they don't need to worry about the reasons listed
When you are pickup up a 100lb object, 6" more makes one hell of a difference. Especially doing it repeadily
I had one years ago, a cherry '53 F250, in the early 80's and it was as handy as your zipper when you have to pee! I had just bought my acreage in the country and used it to haul culverts and all sorts if things. So I know they can be handy. Always wanted another one. I bought my bed before I found a truck to put it on. I would have had to shorten the bed as my truck is a SB and a 1/2 ton at that but it was to be a toy anyway. Money/time/bed weight/messing up a good bed/liking the look of the OBS RCSB put an end to the flatbed for now. Someday......
My 1953 F250
Flatbed I just sold
My 1953 F250
Flatbed I just sold
I like a flatbed for towing and hauling at the same time. You can pull a small bumper pull camp trailer and throw 2 fourwheelers on the flatbed. That way you don't have to tow double. Just build 12" tall wood sides or use diamond plate and they look pretty sharp plus it makes it so you don't have to tie everything down. If you pull goose neck trailers it also makes it nice not having to worry about the trailer snagging the bed side if you have to turn off kilter with the trailer on. I've seen plenty of bed sides almost ripped off due to this happening.
I WISH I still had the '53!!! A 239 Flathead V8 w/4.88 gearing and 25 miles one way to work, wide open at 55 MPH. Scared I'd blow it up.
Wood floor is just what I found. I doubt it's as heavy as all steel plate and stuff doesn't slide as easy, which can be good or bad. I have the tilt trailer to haul stuff still. You DO have to tie everything down on it!
Flatbeds can be useful if you use them for work a lot. But I wouldn't want it on a daily driver.
You say that your farm truck has a rotted out dump bed? Well if it still dumps then you could put a stake body bed on it so you can build your own sides and still be able to dump with it.
We did that with our 93, and it dropped about 700lbs when we got rid of the dump bed and switched to the stake body.
