48-52 hidden antenna success?
Old 01-26-2015, 07:20 PM
49willard's Avatar
49willard
49willard is offline
I do not have a picture but I did a power antenna that is "frenched" into the drivers side of the cab behind the door in basically the same location as the fuel tank fill location which is on the other side. I welded in a tube that is flush with the curvature of the cab at that location.
Old 01-26-2015, 08:08 PM
teardropty's Avatar
teardropty
teardropty is offline
Type in "hidden antenna" on fleabay and you'll find some good ones. They are so compact now that they can be tucked up behind the dash and never seen.
Old 01-28-2015, 03:03 PM
hooler1's Avatar
hooler1
hooler1 is offline
No matter what antenna system you come up with just make sure you have good ground from the outside metal of the radio to the truck's body. The shorter length of cable,wire or braid the better. Believe it or not the sheet metal is a part of the antenna system. I like to use a piece of braided ground strap that you can find in the Dorman HELP parts dept of your local auto parts store.
Old 01-28-2015, 04:57 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,102 Likes on 819 Posts
For my '37 Buick they used the running boards as the antenna, the boards were insulated from the car by ceramic type insulators. From what I've read they didn't work very good, signal would change when you changed directions. Also kind of an elaborate system. Not a suggestion but I thought I'd throw it out there.
Old 01-29-2015, 08:46 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
On my 48 F-3, I laid a stock type antenna over the top of the passenger side window under the cardboard headliner. It worked well.
Gardnangel007
02-21-2011 11:04 AM
bigwin56f100
27
01-26-2011 03:25 AM
mhein
1983 - 2012 Ranger & B-Series
08-12-2008 03:58 AM
tbspks
17
06-22-2007 10:50 AM
1949fordf3
02-02-2006 07:00 AM
Quick Reply: 48-52 hidden antenna success?
