05 f350 6.0 with 64k miles with p0263- cylinder 1 contribution/balance and u1900 network. Truck took longer to crank and when it turned over the truck acted like it wanted to die but didn't, idles great and runs great. Anybody had this problem with a solution? Thanks in advance
I would let it warm up fully, clear the codes, and try restarting it. Be sure to retest for codes at that point. Has it ever had an STC fitting update on the HPOP done?
Very top back of the motor behind the turbo under a cover. Lots of information in the forum about it. You need something to read live data. Smart phone apps with the right adapter.
Ya the icp sensor monitors the ipr pressure. Ipr is what drives injectors. Injectors are what contribute/balance cylinders. Everything works together. Check icp volts
