Vacuum Plumbing Questions
With reguards to the stock 8RT engine in my 52 F6, I need some guidance on the following items:
1) Locating replacement 11/32? vacuum hose from the intake manifold to the firewall plumbing - the original (atleast to me, maybe even the truck) is cracking up and is no longer serviceable.
2) I need to replace the hard vacuum line for the distributor advance since the flare on the carb side broke off. How does one go about this?
2) see here, it really isn't a flare, exactly. https://www.ford-trucks.com/forums/1...ance-line.html
More here: https://www.ford-trucks.com/forums/1...ance-line.html
I got my ford nuts, but nobody has power brake line (and actualy, I think I need 15/32, not 11/32). Napa would only special order me a 50 foot spool for about a bazillion dollars. They suggested 1/2 inch heater hose, but that sounds troublesome and may collapse under the constant vaccume.
Pointers anyone?
Pointers anyone?
Okay, I'm really frustrated - just a recap:
The vacuum line from the intake manifold to the metal tubing on the firewall has aged to the point where it is cracked wide open. I need to replace it. I believe I need to replace it with 15/32 power brake hose - Napa part Number NBH H1451. Napa will only sell me a 50 foot spool, way to much for my 12" run (and way to expensive for the pocket book!). The guy at the Napa counter recommended substituting 1/2" heater hose, but that is not DOT FMVSS 106 compiant.
I also visited AdvanceAuto, Autozone, PartsPlus and tey all just brught 1/2 fuel line, 1/2 transmission coller lines, or 1/2 heater hose lines out.
What am I missing (besides hose!)?
Nothing labeled Vacuum hose - I can get 1/2 flexible fuel line, 1/2 transmission cooling line, and 1/2 heater line by the foot. All of those are positive pressure applications, not negative pressure.
From manifold below carb
To check valve on firewall
I bypassed my booster a couple of years ago, I didn't think my hose was very good, but I went down to the barn and dug it up. It doesn't look as bad as I thought, but it sure must be old, as it's labeled Bendix BK Vacuum Hose. It is about 16" long and still attached to the fittings and short pipe to the manifold and the check valve. I was gonna hold onto it in case I ever decided to have the booster rebuilt or replaced but if you can't find one let me know and I'll send you this one.
