Universal Fuel Line Kit
Okay gang the original steel line on the 64, running from pump to carb is long gone or most of it. The Holley inlet is on the opposite side anyway so it wouldn't really fit. Not quite ready to bend tubing and flare just yet? Also installed a pump that has a filter inside, so now can get rid of inline.filter. There's a filter at the carb inlet too. Can get rid of half a dozen hose clamps this way and potential leaks.
A gazillion places sell these 3' stainless braided hose kits with aluminum fittings, though from the photos none of them look like they have standard flared 1/2" fittings for mechanical fuel pump and carb. What am I missing? Some more fittings probably? What's the deal or, who makes a plug and play kit with flared fuel fittings don't want to make a career out of this project. Thanks.
Talked to NAPA and they sell chunks of hard line. Think I will pick up some that and a tube bender? Just like the idea of no hose clamps, or rubber line to deteriorate, especially with crossover exhaust.
Went with the braided steel flex line many years ago and found it works great, just a matter of detaching at the carb and shift when working on carb and/or engine. They come precut with end pieces attached, or 'do it yourself' kits. Use caution if decide to go this route using the kit, couple different types, one requires special tools, the kit I used did not and the person behind the counter did not know the difference, then it's just a matter of selecting the correct size, shape, and type AN fittings; 6,8, 10 AN, and thread count and shape. If the Carb inlet is on the opposite side may want to consider some type of crossover at the carb???
Posting a link for pic's only, auto shops should carry them.
http://www.summitracing.com/search/s...=AN%20fittings
I wouldn't worry about a tighter radius, what you have will work fine. If that piece of premade tubing is the same as most auto parts stores sell it is cheap thin wall crap and will just collapse if you try to go too small. Ask me how I know LOL. The one on my 292 looks just about like yours..
Had to use a short length of hose to make that one work. My tube bending skills need practice. The Holley has the fuel inlet on the pax side so it needs a pretty sharp bend at on both ends to make it work. This will work for now. Not so much a tighter bend but closer to the outlet on the pump. Running better than ever!
