2.3L PCV valve
#33
#34
Originally Posted by zoti
Since this thread and especially dwildmanj's reply which helped me locate the PCV valve on my '96 2.3L B2300, were very helpful, I am happy to post a picture with the exact location of it.
So here it is. PCV valve location in a '96 2.3L engine. Right under the #2 spark plug on the drivers side. It's the grey plastic thing in the middle of the picture. It was hard to get to it ans people with big hands will have to remove the #2 spark plug cap (which I couldn't pull out with my bare hands). I only removed the electric connector with the red wire which goes to the component that sits right above the PCV valve.
#35
Andy,
That pic is for the 3.0 and 4.0 engine not the 2.3L engine. Where is the oil seperator it refers to?
Originally Posted by Andywk
I just looked under the hood so I could be more specific. There is a hose running out from under the rear of the intake manifold on the drivers side. Must come from the manifold instead of the valve cover as I previously stated. It is really dark under there and I felt up along it as far as I could but never got to the end of it. I need a smaller hand for that. It comes out and curves down just between the intake manifold and the firewall. Right after it curves down is where the PCV valve on mine is located. The hose is on top of the valve and the other side of the valve plugs into another hose/tube that then goes down under the engine.
If you pull up on this hose the PCV valve will come out and be on the end of the hose. You can then put a new one on and plug it back in to the bottom hose/tube.
The Haynes manual for 93-97 ranger shows this on page 1-25. It is in illustartion 20.1a. The only confusing thing about this picture is the orientation of the engine. The first time I looked at it I couldn't make it out. Looking at it again there is an arrow locating the location of the front of the engine. Then it became clear.
Hope this helps.
Hope this helps.
#36
#37
The one I picked up for my 91 4 cyl had a metal part and a plastic part with two nipples sticking out a right angles. There was also a plug for one of the nipples. I took it back and showed them a drawing from the 91 factory service manual that had a nipple on one end of a straight through design. The counterman took the valve and pulled the plastic end off and, lo and behold, there was a straight through design with a nipple on one end. It fitted perfectly. Ford engineers must have a lot of fun finding different ways of hiding the PCV valve. After all, if it was always in the same place, what would we have to talk about?
#38
Hope this helps.
Hope this helps.
#39
#40
#41
#42
I looked today where the Autozone repair guide said it was (under the intake, between intake and block) and there was nothing there. The only vacuum hose that goes under the intake (that I can see) plugs into a port and goes into the vacuum canister. Anybody know where I can find this?
shultzaberger
1983 - 2012 Ranger & B-Series
01-26-2023 09:49 AM
