OD light stay's on!
I just checked Motorcrafts website for the calibration code interchange. It appears Ford doesn't want us looking up anymore old data as its no longer available before 1994-96.
Hopefully Subford can help us out or NumberDummy. I looked for the suffix XXXX-CA, and could not find it, but several others that may be close.
Is it 2wd or 4wd?
Is it 2wd or 4wd?
I put in 1992 on the Advanced Auto website and found this. It's for E4OD but the suffix is CB. I don't know what the suffix means.
BWD Engine Control Module ECC1850: Get the best Engine Computer at Advance Auto Parts
I also found this one at Oreilly's and it's a exact match on the number but does not say E4OD.
Cardone Remanufactured 78-5279 - Engine Control Computer | O'Reilly Auto Parts
Update!
I installed the new CM form Oreilly's (exact part# match) and WALAA! It Works!!!! the OD light never came on and the trans shifts ever gear. BUT, it shift hard. At least now the check engine light came on so I have a code to follow. I'll run the code and get back to ya. thanks. I suspect a TPS, MPLS or VSS.
'OFF' OD. button on shifter stays on/no start
What makes you think the MLPS is the problem?
I think you have more than one problem here. The OD light staying on is probably a wire shorted out in the shifter or column somewhere. Ford programming is to flash the OD light when there is a transmission issue, not keep it on continuously.
The shifting problems you have are probably another thing entirely. Check for codes and report back!
madvillepocket
05-16-2015 09:04 PM
