2006 Keyless Entry on the door help.
I have a 2006 F-350 lariat. I bought the truck used and it has the keyless entry on the drivers door. When I purchased the truck I didn't get the code for the keyless entry. I have been able to find the factory code and it does not work. I believe that the previous owner has put a different code in it. I was wondering if anyone knows if I can reset the keyless entry code back to the factory code so I can use it? I have installed a Viper remote start/alaram on the truck. Thank you for your help.
the keyless entry code is not owner programmable. the owner can add secondary codes.
Even the dealer can not program a new code, they can only retrieve the existing code as i understand it.
Did you check on the computer/ECU for the code?
You can get a dealer to hook the computer to it and pull the code. They will probably charge 35 to 50 to pull the code.
And yes, you can use the keypad even with Viper setup. Just be aware you might set off the alarm if it armed when you use the keypad.
excursion2001
General Automotive Discussion
02-09-2004 10:10 AM
