Temp Gauge Reading Low?
Followed this thread with interest. Answer comes at the end of thread. Maybe your culprit for the fluctuating gauge..
BRGDS,
patrick
Radiator - Likely? Older van, so scale may be causing blockage. Temps have increased with time. No fluctuation between sitting and highway speeds supports blockage. No issue when outside temps are colder also seem to support blockage theory.
Conclusion: Radiator is okay with winter temps, but reaches it's cooling capacity with summer temps.
BRGDS,
patrick
Jose,
Did you take any actual temp measurements at the radiator? Like with either a contact type thermometer or one of those IR sensors? You can compare these readings to your other vans where the temps read more "normal"
Last summer on my 97 3.0 the bypass pipe that the temp gauge sensor screws into started leaking. After replacing it, my gauge went from running around the R to running right around the A in normal. Replaced the sensor. No change. Replaced thermostat. No change. Installed complete aftermarket gauge. Read 240 degrees. The highest reading I got with an IR gauge was 210 with ambient temp over 90, A/C on. The van was driven all summer with this reading and no physical indications of overheating.
Duct Tape Racing
02-04-2018 06:22 PM
nolan62
01-09-2014 02:00 PM
Hussler
09-27-2013 05:57 PM
