6.2L V8 Discuss the 6.2L V8
Rotating Tires
Old 01-06-2015, 06:05 PM
don123's Avatar
don123
don123 is offline
Rotating Tires
I want to rotate tires on my 2015 F350 6.2 CCLB. The manual says to put rear tires up front staying on the same side and crossover front tires when putting them in rear. I went to my dealer and the service dept. says "keep tires on the same side when rotating tires". I told him manual says different. He looked at me puzzled? Anyone rotate there tires on a new f350? I have the Michelin LTX A/T 2 275/70/18E AT tires. I will torque lugs to 165 ft. lbs like the manual says even though that seems like a lot.
Old 01-06-2015, 06:15 PM
rjcorazza's Avatar
rjcorazza
rjcorazza is offline
I checked my manual on a 2011 F250 CCLB and was suprised to find the same recommendation. I have always rotated tires front to rear on the same side.
Old 01-06-2015, 07:07 PM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
I have mine done at the dealer every 5k miles when I get my free oil change. I confess I don't know which pattern they use, but they charge me $16 to rotate 4 tires, which is a steal imo.
Old 01-06-2015, 07:09 PM
Pit Crew's Avatar
Pit Crew
Pit Crew is offline
I have been rotating my tires like that for at least 15 yrs,no problems. Back in the day,they always kept radial tires on the same side?
Old 01-06-2015, 07:13 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
That Was a common half x rotation years ago . Full x was common also . Michelin tires and other quality tires , rotated properly , will last longer that way . Want to mix it up ? add the spare into the rotation sequence , We use to ....
Old 01-06-2015, 07:20 PM
don123's Avatar
don123
don123 is offline
I thought about using the spare but it's mounted to a steel rim and I would have to get it dismounted and balanced so just the 4 for now.
Old 01-06-2015, 07:24 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
Yes . That was when we still used common rims for all wheels , even the spare . Proper pressure , proper rotation , proper balance and alignment . They all lead to longer tire life .
Tobys351.9
09-18-2021 10:13 AM
92Custom
06-27-2002 03:40 PM
weldman
01-31-2002 02:43 PM
Quick Reply: Rotating Tires
