1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 V10 Frozen gas line possible?
Old 01-06-2015, 05:04 PM
96mark8's Avatar
96mark8
96mark8 is offline
Hey guys my 2001 F250 V10 Is cranking but wont start. It worked fine yesterday but when I went out to start it this morning it barely was cranking. I put in a new battery and the starter seems to be turning fast enough but the engine wont fire up. I have a full tank of gas but is it still possible I have a frozen gas line? it was about 11'F today with a real feel of 0'F and we have had snowy roads the past two days(maybe ice and snow built up on outside of lines???). If not what do you guys think I should look at next? Alternator is about 3 years old and starter is about 4 or 5 years old. Any input would be appreciated!
Old 01-06-2015, 06:46 PM
4x4sd's Avatar
4x4sd
4x4sd is offline
maybe your fuel pump is frozen...j/k . ck fuel pressure, if you cant, spray some carb clean in the throttle body..if it fires then you know what it is. becareful, everything seems to break when its that cold
Old 01-06-2015, 07:19 PM
Army RET's Avatar
Army RET
Army RET is offline
I had a similar story last year, good turn over but no start - coincided with brutal cold.
Turned out to be the fuel pump; and as my fuel filter was of an un-known age it too was replaced, just to be safe.
Old 01-06-2015, 07:20 PM
96mark8's Avatar
96mark8
96mark8 is offline
I cant easily check fuel pressure unfortunately. I can hear the fuel pump cycle when I turn the key however. Spraying starter fluid (similar to carb cleaner I am assuming) into the intake is the next step I will try tomorrow. I will also pour some HEET into the gas tank tonight but I am guessing that wont do much if the lines are already frozen. If the engine is able to at least fire for a second or two with the starter fluid I am guessing it is safe to assume it is either a bad fuel relay/ pump or frozen fuel lines? And if nothing changes I guess I will start to look other places. On Sunday it is supposed to be 31F so I really hope it will at least start then or else I have other issues it seems.
Old 01-06-2015, 07:22 PM
96mark8's Avatar
96mark8
96mark8 is offline
Fuel filter is about 2 months old, fuel pump is original tho so that could be the issue. I really hope that is not the issue I don't want to have to change that out in the cold lol.
Old 01-06-2015, 08:09 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Can you get it towed to a warm garage?
Old 01-06-2015, 08:19 PM
96mark8's Avatar
96mark8
96mark8 is offline
Unfortunately no, I am up at school right now so there is no garage I could bring it too.
Old 01-06-2015, 08:25 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
I have seen fuel filters freeze solid and cause a no start . They do a good job of trapping water . Best of luck !
Old 01-06-2015, 10:42 PM
96mark8's Avatar
96mark8
96mark8 is offline
Thanks, I will make sure to swap that out before I start messing with the fuel pump! I just went out and got some starter fluid and put a bottle of HEET in the gas tank, so we will see how it goes tomorrow.
Old 01-07-2015, 06:25 PM
96mark8's Avatar
96mark8
96mark8 is offline
Well went out and tried again today and realized that I cannot hear the fuel pump come on when I put the key in the on position. I should at least hear that even if the lines or filter are frozen correct? I was able to get starter fluid into the intake and get the engine to actually run for half a second until it died so I am guessing this is a fuel pump issue :/ I will try and change the fuel pump relay tomorrow but my hopes are not that high. Dealer quoted me 600 in parts and labor and seeing as I don't have the tools or garage to get this done myself it looks like I will have to bite the bullet.
Old 01-07-2015, 06:43 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
Check the inerta switch and all your fuses before you throw in the towel . Best of luck !
Old 01-07-2015, 06:49 PM
96mark8's Avatar
96mark8
96mark8 is offline
I will make sure to do that thanks!
Old 01-07-2015, 07:26 PM
Army RET's Avatar
Army RET
Army RET is offline
That price is outrageous; call around and solicit prices for this job/ with or without parts, but be consistant.
Old 01-07-2015, 09:19 PM
4x4sd's Avatar
4x4sd
4x4sd is offline
yes, always ck the simple stuff first.....but if you don't have a offroad 4x4 package (metal shield on the plastic gas tank) on your truck, take a plastic mallot and pound it on the center bottom of tank while another person either crank it or cycle the ign. key every 2 seconds 4 times max. you never know , you might be able to loosen up the brushes on the pump.... good luck
Old 01-07-2015, 10:14 PM
96mark8's Avatar
96mark8
96mark8 is offline
How much should I be looking to pay? The dealer is charging $244 for labor and I would provide the pump off Rockauto. The pump is a complete Motorcraft assembly and is $300 it is the exact same Motorcraft part number that the dealer wanted to sell me but they wanted 500 for it! After taxes i am guessing I will end up are 600 total if i buy the pump myself. I also checked at a local corner garage and he quoted anywhere between 550-750 depending on what pump I had ( I thought all gas engine superdutys had the same fuel pump) and he did not give me a brake down of what was parts a labor cost.
I don't think 244 is that outrageous for labor to change a fuel pump especially from the dealer? And I know that the pump itself is expensive but I would like the peace of mind that I won't have to deal with it for the remainder of the trucks life.
And unfortunately I do have the off road package so I cannot hammer on the tank.
Quick Reply: 2001 V10 Frozen gas line possible?
