Planning/plotting a 6.0 build. Advice and comments welome!!!
2006 F350 4X4
If you have the later oil rails change the branch tube and use the later HPOP and cover or get a later engine with the better HPOP in it. Replace the cam with a stage2 cam from colt cams. Its cheaper than a factory replacement cam anyway. High rev springs too. Ya won't regret it! Use factory gaskets.
Okay, here's what I've settled on, I think.
1. Keep the factory turbo, just give it a real good cleaning, and a rebuild kit.
2. Casserly 155cc injectors
3. Atlas80 FICM
4. ARP studs
5. Do I need fire rings?
6. EGR block off (Welded freeze plug)
7. Coolant filter
8. 200 amp alternator
9. Blue spring
10. New oil cooler
Much of the rest will depend on how the new block surveys. I'm hoping to get it picked up this weekend.
3. Atlas80 FICM
4. ARP studs
7. Coolant filter
9. Blue spring
10. New oil cooler
3. Atlas80 FICM
4. ARP studs
7. Coolant filter
9. Blue spring
10. New oil cooler
3. Atlas80 FICM
4. ARP studs
7. Coolant filter
9. Blue spring
10. New oil cooler
3. Atlas80 FICM
4. ARP studs
7. Coolant filter
9. Blue spring
10. New oil cooler
3. Atlas80 FICM
4. ARP studs
7. Coolant filter
9. Blue spring
10. New oil cooler
As far as I've heard, it will add to reliability.
I know the feeling!
Riffraff makes one a little cheaper.
So are you going to turn up the boost after the rebuild? If not do not waste the $ on the o-ringed heads!
Why do you want to keep the EGR cooler? Get rid of that POS! I installed this on my truckhttp://www.iprresearch.com/IPR-GEN2-EGR-Delete-Kit-for-all-2003-2004-Ford-Powerstroke-6.0-will-fit-F250-F350-F450.html
No hose to worry about! Nothing to break a few years down the road and accidentally get coolant into the wrong places on the engine!
Stud it, tune it! After market exhaust manifolds with a pyrometer in each one! 4 inch exhaust from the turbo back! Eliminate the cat and muffler!
Wicked wheel will keep the same sound (its a 10 blade turbine irregardless) just a little more boost and better throttle response
#28
#29
UPDATE:
Heads are both toast. Kaput. So, it looks like I'm going with a brand new pair of Cifics. $1300 assembled.
Dropping the block off tomorrow to be surveyed. Machinist is working up a quote for me to go ahead and install hardened valve seats in the new heads. Don't know if it's necessary or not, but sounds like a good ounce of prevention. After mixed reviews, O-rings are out. I'll be staying >600HP, so the consensus is that O-rings just aren't worth it..
#30
I replace a bunch of aftermarket injectors that were just installed. In my world I can't understand why people buy them for daily drivers. Of course,, I only see broken stuff at the shop. I will not install ANYTHING but OEM injectors. Bigger injectors (if they function properly) will only increase the "roll coal" effect.
