Planning/plotting a 6.0 build. Advice and comments welome!!!
Old 01-07-2015, 07:21 AM
Per4mance's Avatar
Per4mance
Per4mance is offline
If your going that far into it try the 6.4 cam, lifters and push rods. I haven't tried it myself but I heard great things about it in a 6.0 (power and mileage gains) I was reading this on another fourm
Old 01-07-2015, 08:50 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Hmmm--makes me want to pull mine and go to town
2006 F350 4X4
Old 01-08-2015, 08:08 AM
Per4mance's Avatar
Per4mance
J and K Engines has a stroker kit too!
Old 01-09-2015, 07:51 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
If I had the time and funds I'd be all in!!!
2006 F350 4X4
Old 01-10-2015, 02:49 AM
ul37's Avatar
ul37
ul37 is offline
If you have the later oil rails change the branch tube and use the later HPOP and cover or get a later engine with the better HPOP in it. Replace the cam with a stage2 cam from colt cams. Its cheaper than a factory replacement cam anyway. High rev springs too. Ya won't regret it! Use factory gaskets.
Old 01-28-2015, 03:25 PM
Jeff Watts's Avatar
Jeff Watts
Jeff Watts is offline
Okay, here's what I've settled on, I think.
1. Keep the factory turbo, just give it a real good cleaning, and a rebuild kit.
2. Casserly 155cc injectors
3. Atlas80 FICM
4. ARP studs
5. Do I need fire rings?
6. EGR block off (Welded freeze plug)
7. Coolant filter
8. 200 amp alternator
9. Blue spring
10. New oil cooler
Much of the rest will depend on how the new block surveys. I'm hoping to get it picked up this weekend.
Old 01-28-2015, 04:56 PM
twfish's Avatar
twfish
twfish is offline
3. Atlas80 FICM
4. ARP studs
7. Coolant filter
9. Blue spring
10. New oil cooler
Since your pulling apart the turbo might as well get a wicked wheel nice $200 well spent
Old 01-28-2015, 05:11 PM
Jeff Watts's Avatar
Jeff Watts
This may sound childish, but I like the sound my turbo makes. Not saying I won't upgrade it, but I love that low whistle at idle.
Old 01-28-2015, 05:15 PM
Rellick's Avatar
Rellick
Rellick is offline
3. Atlas80 FICM
4. ARP studs
7. Coolant filter
9. Blue spring
10. New oil cooler
I just replaced my heads about 5k ago. After they were in I saw a set of ringed heads for something like 1800 (IIRC). I bought OEM for 22 or something (dealer price matched Tousley). So if you are getting new ones...
As far as I've heard, it will add to reliability.
I know the feeling!
Riffraff makes one a little cheaper.
Old 01-28-2015, 06:51 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
So are you going to turn up the boost after the rebuild? If not do not waste the $ on the o-ringed heads!
Why do you want to keep the EGR cooler? Get rid of that POS! I installed this on my truckhttp://www.iprresearch.com/IPR-GEN2-EGR-Delete-Kit-for-all-2003-2004-Ford-Powerstroke-6.0-will-fit-F250-F350-F450.html
No hose to worry about! Nothing to break a few years down the road and accidentally get coolant into the wrong places on the engine!
Stud it, tune it! After market exhaust manifolds with a pyrometer in each one! 4 inch exhaust from the turbo back! Eliminate the cat and muffler!
Old 01-28-2015, 06:53 PM
Restlesswildman
As much as folks love the BPD oil cooler relocation kit....for that kind of money you can replace the cooler 2xs !
Old 01-28-2015, 08:37 PM
twfish's Avatar
twfish
twfish is offline
Wicked wheel will keep the same sound (its a 10 blade turbine irregardless) just a little more boost and better throttle response
  #28
Old 01-28-2015, 09:11 PM
Jeff Watts's Avatar
Jeff Watts
Good to know on the wicked wheel. As far as plugging off the EGR, there's been rumors of visual inspections in the future, so I figure just leave it, and block it off. Plus, it maintains the stock exhaust mount rather than hanging the weight on the turbo housing.
  #29
Old 02-04-2015, 02:23 PM
Jeff Watts's Avatar
Jeff Watts
UPDATE:
Heads are both toast. Kaput. So, it looks like I'm going with a brand new pair of Cifics. $1300 assembled.
Dropping the block off tomorrow to be surveyed. Machinist is working up a quote for me to go ahead and install hardened valve seats in the new heads. Don't know if it's necessary or not, but sounds like a good ounce of prevention. After mixed reviews, O-rings are out. I'll be staying >600HP, so the consensus is that O-rings just aren't worth it..
  #30
Old 02-05-2015, 09:29 AM
Super Duty Service's Avatar
Super Duty Service
Super Duty Service is offline
Former Vendor
I replace a bunch of aftermarket injectors that were just installed. In my world I can't understand why people buy them for daily drivers. Of course,, I only see broken stuff at the shop. I will not install ANYTHING but OEM injectors. Bigger injectors (if they function properly) will only increase the "roll coal" effect.
Quick Reply: Planning/plotting a 6.0 build. Advice and comments welome!!!
