Well the truck is still getting painted working on the wood
Yes, all of 6 sides of the wood have been sealed with epoxy including the drilled holes. As far as the varnished finish... it isn't really necessary for the bottom since it will not see any UV light. But it just feels right to finish it. Ya know?
Received 4,135 Likes
on
SKU: West System Epoxy Prepackaged Kits
Choose your item: Gallon Kit with 207 Hardener: #WSY 105207B - $151.95 x 1 = $151.95
Price: $ 151.95
Sub-Total: $ 151.95
SKU: Z-Spar 2067
Z-Spar 2067 Ultra-V Gold Gloss Varnish ...Special Offer!
Captains Ultra Clear Varnish 2067 is a premium urethane varnish specially formulated for maximum durability and ease of application. The strong ultraviolet inhibitors in Captains Ultra Clear help it maintain outstanding gloss long after ordinary varnishes have faded. Ultra Clear’s tough surface provides remarkable resistance against scratching and chipping. It’s easy brushability, excellent leveling capabilities, and fast build-up are among its many attributes that make it a pleasure to apply
Sold in Quarts only
Price: $ 31.34
Qty: 2
Sub-Total: $ 62.68
$215 total in materials.
The tint was just minwax water based stuff you can pick up at your local hardware store, just make sure you get the water based stuff as the epoxy will not work very well over some oil based "stains"
Price: $ 151.95
Sub-Total: $ 151.95
SKU: Z-Spar 2067
Sold in Quarts only
Price: $ 31.34
Qty: 2
Sub-Total: $ 62.68
on
Here is the process I am using
Process:
1) red oak purchased from midwest early ford
2) sanded 120 then 220 with orbital sander
3) water based tint on top and bottom (minwax water based)
4) 3 coats of west system epoxy on the bottom and sides, allow to cure 2 days
5) sanded sides/ends, removed runs and touched up tint
6) 3 coats of west system epoxy on top and sides/ends, allow to cure 2 days
7) touch up any bubbles and low spots with epoxy and allow to cure
8) sand epoxy flat with 120 and then 220 on orbital sander
9) wet sand by hand with 220 or 400
10) clean with acetone wipe down and then tack
11) 2 coats of Petit 2067 varnish on the bottom between coats - 400 grit wet sand followed by wipe down with mineral spirits and tack
12) final will be 3 coats of Petit 2067 varnish on the top and sides with 400 grit wet sand. After the last coat I will sand the top visible surface with 800 then 2000 and then polish with automotive polish and wax.
all told 70-80 hrs of work.
Haha thanks. Unfortunately with our recent addition to the family, it took me several months to find enough free time to get these done. I imagine you could find a place that can finish them cheaper and faster than I could. But appreciate the compliment!
#28
on
#29
