FUEL/IGNITION?
#61
#63
#67
#69
on
Bud take all the plugs out so it will turn over easier.
Take the compression out of the equation and it will
help to turn it the other way. Than the bolt shouldn't
come loose. But with the breaker bar on the bolt get
it as tight as you can till the engine turns. Than smack
it a few licks with a BFH. That should set it so with the
plugs out it will turn that way. It works for me.
#70
#71
on
If you still have a problem you'd blame the trouble on advancing to gear and may pull it back down to reset back to '0' with a double roller chain.
Do not buy a OEM type timing set as those were made with a smog days in mine an set oem were retarted.
I'd say don't be doing stuff your don't know will help you or cause you timing issues and ping running low octane gas.
This is ok for 351-c4 as he like pulling things apart to seeing what makes them tick.
An then comes here an ask for help when his vehicle will only runs on
3 wheels & not 4, Or something like that!
Orich
#73
Set that bad boy to TDC #1 cylinder on COMPRESSION stroke. With all the plugs out like Arctic said you can spin it easy. Turn the engine over with your thumb on the hole for #1 cyl. When you feel pressure pushing on your thumb it's coming up to TDC on that compression stroke. Now keep spinning the crank until the timing mark is at "o" (TDC). With it set here the Marks on the old timing gears will prolly not be lined up like they should be because we think the chain has slipped. If this is true, spin the cam and it's gear until the gear's line up marks do indeed line up. Cam gear's mark at the 6 o'clock position and the crank gear's position at 12 o'clock. Thus the two marks are facing each other. In a straight line. This straight line starts at the center of the cam gear's bolt, through the cam gear's mark, through the crank gear's mark, to the center of the crank. Now take the old gears and chain off and put on the new parts. Oil 'em down good with fresh engine oil so they have some on 'em on initial start-up.
#75
on
The key is the only thing in it's way to slid off. I guess you have removed the timing cover by now. I've never had any real problem remove the crank spacer.
But have heard about other having them. May be driving a good sharp wedge between the spacer & the oil shield. Put some type the lube or wd-40 on the crank shaft snout tip it with a hammer lightly trying to work the lube inside to help free it.
If that do it then try using a crow bar behind the crank gear sprocket to get it to move.
Orich
Orich
