Best way to start, when cold '83 F150 4.9L 6 auto
When cold the choke door goes fully shut. But of course like you said it won't run very long like this. So each system has some sort of vacuum mechanism that when the engine starts and vacuum builds, it cracks the choke door open.
Some have a external diaphragm unit with a lever, and the Holley's have a little piston made into the housing where the round black piece bolts to.
See what I mean? These things are involved. And guess what? This choke-pull off has a spec. You have to take your finger or some other method and pull the choke pull-off back, and then measure the crack at the choke. If the crack is not large enough, the engine can flood out or burn rich. If the crack is too wide the engine will start up and then instantly stall as the choke door opens too much. On most of the external units, you have to take pliers and bend the rod to adjust it.
It's still a gasoline engine, no different than starting a mini bike or lawn mower or chain saw. The industry has come up with a method (automatic choke) to put into place so people don't have to futz with this stuff on their own... which is great when it works, not so great when things go wrong.
Originally Posted by Nothing Special
Under all of this of course is having the choke and carb set up correctly. But carbed engines have more ... personality than EFI. You need to get to know them.
I bookmarked this link as reference info.......
Installing Automatic Choke on a Holley Carburetor - Ford Mustang Forums : Corral.net Mustang Forum
Thanks!
And this quote from the above article:
Originally Posted by Ray III
Bottom line, if it "runs like it's carbureted" IT'S NOT PROPERLY ADJUSTED! There should be no difference from an identical fuel-injected engine; either system of fuel delivery is well tuned or it's not.
daniel.bow
06-07-2014 06:28 PM
cak7700
11-15-2011 08:33 AM
hoxiii
01-18-2008 12:59 PM
jellybellyjean
08-16-2002 12:58 PM
