Heating problems
Heating problems
1998 e150 club wagon, 5.4 engine with 154k miles and front and rear air/heat. When the engine is warmed up the front will blow air hot enough to make you sweat but the rear vents blow ice cold all the time. Engine coolant is full and have not observed any leaks(not had to add coolant in the 25k miles I've owned it). Any ideas?
To be honest with you, I have no idea how long it has been like that. We have had it for about a year and a half now, but neither the wife or I had ridden in the back in winter until this year. The kids didn't complain last winter, but they hadn't complained this winter either. My wife rode back there a few weeks ago and immediately said it was blowing cold. Might have been messed up last year, might be recent.
I had same issue in an older van I had. The rear heater core was no good so the previous owner had shut the valve going to it. If I remember correctly, it should be on driver side (underneath about midway back) .
Hope it helps.
I'm having heat problems in my 93 Econoline now. Front heater core barely gets warm as does the radiator. Ran it in my driveway for 2 1/2 hrs and temp gauge never came to "C". (C - NORMAL - H on gauge in dash)
Put new thermostat in 2 weeks ago and zero change.
After running in driveway, both hoses and radiator just BARELY warm.
Any thoughts?
Hope it helps.
Any thoughts?
sgrol
03-10-2006 02:38 PM
