1985 302 mfi, rod knocking
Found a '85 F150, clean body, transmission good, but the engine knocks. So I pulled the pan, found #1 and #5 rod bearing worn badly, put in standard bearing back in. Well it is still knocks , but not as hard as it was. I found an '84 donor truck with two 302's. Tore down the engine in the bed, had the block bored .030 over and had the crank turned .010/.010, new cam, lifters, pushrods, valve job. In the process of building it to replace the knocking engine. Here is my question, I would like to change out the ignition system with a Dura spark system, put not sure the impact on the fuel injection and computer. Any help will be appreciated.
A Duraspark II ignition and EFI/computer are mutually exclusive; you can have one or the other, but not a mixture of the two.
From the Sticky at the top of this forum (something you might want to look through before asking):
DSII DS-II DS2 DuraSpark II CONVERSIONS (SWAPS)
https://www.ford-trucks.com/forums/10...on-how-to.html
https://www.ford-trucks.com/forums/96...-86-i-6-a.html
https://www.ford-trucks.com/forums/10...g-harness.html
I look over the forum to find out if I could put a Dura spark on a fuel injection engine and didn't find any thing. Well I guess I'll have to stay with the thick film dist. I have a another '85 that I will Changing from a I6 to a V8 in. in the spring, I was going to change the dist. to a Dura spark system on the six. Thanks for the info.
You've been on FTE for ~4 years yet have only 10 posts... this averages out to 2.5 posts per year... which means you are here only to absorb information, not to also pay back by helping others with what you know.
That's OK, and some of us here put a LOT of work into making certain, commonly-asked-for information more easily available by placing it in Stickies and Subforums... which makes it easier for people to find stuff.
And it's really discouraging for those who go through all that work to have people not take advantage of it....
JayzDaddy
01-04-2015 10:03 AM
im2tall33
05-19-2011 04:49 PM
LARIAT 85
22
01-11-2011 09:49 PM
86ford302
12-18-2009 06:53 PM
