71 F100 rear drums
71 F100 rear drums
Ok Total nubie here IV always work on Honda LOL
saw this truck had to have and right now the rear drums are kicking my ***
this is a 71 F100 long bed 2WD with a 369cdi, and I can even get the rear drums off is there a pin that need to be pulled out or a screw I need to get these off? Any help will be VARY MUCH APPRECIATED
The self-adjusters make sense if you understand how they work. They need two tools (screwdrivers/brake spoon, etc) to loosen, one to push the adjuster lever out of the way, and another to turn the star wheel. Only one tool would be required to tighten the shoes, but It should not be possible for them to loosen otherwise. Rotate the star adjuster towards you (or CCW) to loosen.
Propane is your friend here, and a BFH, PB blaster, etc. Heat up the drum and pop the corners of the drum pretty good, it will come loose. A little anti-sieze on the axle hub makes things easier the next time.
ptexrican
11-13-2018 05:31 PM
nlareau
04-21-2011 08:13 AM
chappys4life
08-18-2010 08:27 PM
pngasius4
06-15-2000 09:14 AM
