Are these injectors normal?
It could be an injector flow imbalance. Too much readin' and replyin' lately, I don't remember if we discussed a chip/program in your truck.
It does this "chug" in neutral and in gear? What happens when you powerbrake? What happens when you keep it in 2nd gear and you take the speed up through the problem RPMs?
Truck is not chipped. The shudder/imbalance is subtle and does it in neutral, park or 1st and 2nd. Powerbrake seems to take a little of it away but not much. My wife can't even feel but I can. I am OCD about noises and vibrations/shudders I can't explain. As a helicopter pilot ALL unexplainable noises or vibrations are BAD and will be investigated!
Is there a link on how to ohm the IDM?
The closest I can get you is the UVCH link in my signature. If it's a subtle chug, you can verify you have one cylinder a bit "off" by checking the exhaust manifold temps on each port (laser thermometer). I've done this with my truck and found one cylinder that doesn't match its mirror on the other side. That's a work in progress.
BRIAN NORCAL
16
12-02-2016 08:23 AM
aocabrown
02-15-2009 01:49 PM
KJLYPW
06-04-2006 11:25 PM
