. Depends on cam size/spec.s, combustion chamber and piston prep., ignition curve/advance, thermostat temp., cooling capacity, usual workload, and engine quench distance... etc...
. Usually 9:1 or slightly more... lots of variables... I'd aim for 9 for efficiency's sake and do what's necessary to make it work if sticking with 87 regular... avoid the actual 7's of '72 and later engines...
That's where I'm having trouble. This is going on a 79' 2wd that will be used as a daily driver and to occasionally pull a trailer (around 3-5 thousand pounds, 3-4 times per year) I want a strong motor that can run on the cheap gas. I'll be running an Edelbrock 2171 intake with a street demon 625 carb, just haven't decided exactly how I want to build the motor from here.
Back in the day of when lower octane 1st hit, Crower had a series of grinds that would allow up to a 11:1 CR and not exceed 150 psi.....of course with all the right parts.......
