5.4 missing while under load
I have a 2007 super duty with a 5.4 it has 93000 miles on it. When you start up a hill it will shuter like it is missing but check engine light is not on could this be a coil and how would check for a bad coil if check engine light is not on to use meter. thanks for any help Darrell
on
You will have a misfire counter on the scantool. Even if you dont have a CEL it will count the misfires on all 8 cylinders. So you can see which one is acting up. I agree sounds like a plug or a COP, a coil or boot, if you narrow the misfire to a cylinder remove that plug and look at the porcilian around the plug, you may see a carbon track going from the top to were the nut is. Check the PVC hose too, they rot out at the back of the intake causing a lean condition as well.
Scanner said #8 misfire again. Checked the plugs. Car had 112k on it and I'm sure they'd never been changed. The gap should be .054 on them but each plug was well over .080.
Replaced the plugs, made sure they were properly gapped and put dielectric grease in all boots and it's been good for 7-800 miles so far.
Although not quite the same motor in my Crown Vic, I'd read that it's a good idea to put Permatex copper anti seize on the threads of the new plugs. Not an expensive insurance policy for future removal so I went ahead with it.
on
I disagree with changing the coil packs at this point. With 93k mikes on those plugs, they should be replaced... Yes they can be a real b!tch... You may want to consider supporting your local Ford Dealership to have this done.. At the same time, they can determine if you have a weak coil and replace it as well..
I started getting a misfire under load at about 95K miles, I swapped COP but was never to track it to a coil changed plugs and all have been fine for the past 25k miles.
Get a quote before you take it in for a plug change, my quote was $400 - $900 depending how many plugs broke. I purchased a Lisle 65600 tool about $60 used it on the three plugs that broke sold it on ebay for $50.
I assume you have the two piece plugs that like to break.
