T18 to Mazda 5 Speed
Alright I check with him. Another question (they just keep comin) will the starter I have work or will I need to get one from an newer model? Also found this ZF 5 speed while browsing for a M5R2. Its 2wd but doesnt clearify if its a big block or small block bell housing. Figured Id throw it up here to help somebody if they are looking for one. $250
(http://m.ebay.com/itm/281533424115?nav=SEARCH)
Thank you Gary!
John,
If you were close to Atlanta, that is a very fair price on a stout trans. And yes, it is the right bell housing, from his description at least.
I do think that you'd be happier with the Mazda though, for what you plan to use it for. It's not nearly as tough as the ZF, but, the simple way of putting it: The Mazda will drive more like a car transmission, the ZF is more of a truck trans, if that makes any sense. I have both, also behind 300s (the ZF5 was a swap of course). The Mazda is a much more daily driver friendly transmission, whereas the ZF I use everytime there's a heavy load that needs moving. Also, with the M5od, the ratios are alot closer, so short shifting is smooth as silk, the ZF has wider ratios and loves to build revs.
My $.02.
John,
My $.02.
Yeah I thought it was a pretty good deal but like you said Im looking for more of like a car transmission. Also Im all the way over here in Texas so it wouldnt be worth it after driving there to get it. A couple more questions and I promise ill stop lol. Are the M5R2 and T18 transmission the same length? Coming from the 3 speed to the T18 we didnt have to modify the driveshaft. Another question, when installing the T18 my floor pan wasnt removable and I needed it done quick so i cut the floor pan out pretty nasty like with an air hammer (regret it completely now) and welded some washers to it and drilled holes for bolts to hold it down. Can I get the floor pan from the donor truck and fab it into my truck? With a 2inch body lift (installed from previous owner) will the clutch linkage and shifter clear and function okay? I could always remove the body lift but id have to modify my exhaust, rear bumper (prob go to roll pan) and the tires on it right now (brand new) might not clear and of course have to get o.e.m. body mount bolts.
Thanks, John
Thanks, John
There is no clutch linkage. That's what the hydraulic clutch thing is all about. I don't know about the lengths, so get ready to modify the shaft again, or if the donor is the same wheelbase, just get the shaft out of it.
I don't see why you could not get the floorpan piece out of the newer truck. It unbolts.
No such thing as a dumb question. He needs a new clutch assembly as the T18 is a mechanical clutch and the M5od is hydraulic.
The trans would have to come from a truck with the small block pattern, ie 4.9 5.0 5.8... There were SOME 97 4.6s that shared this pattern I hear, but otherwise, 1997 and down.
#28
Also what you may not know; The 5 speed trannies did not have a separate bellhousing like the older 4 speeds. The bell is part of the tranny. So that's the reason you are stuck using a hydraulic clutch, there is no provisions in the integrated bell for a mech clutch.
brandonrmeredith
05-17-2015 09:38 PM
niteowl
18
03-03-2014 03:44 PM
mountaineer27
21
04-28-2013 03:06 PM
Vance in AK.
12-18-2007 05:55 PM
