Brake Lights
Since the turn signals use the same bulb filament, it isn't the bulb. I might check the wires at the master cylinder. There are two wires at the top, pull them, connect them, turn the ign sw on and see if the bulbs light up.
Yes then the that switch may be bad.
No keep looking at the front. Switch needs to be in on position. This may not apply to your truck but does mine.
John
John
Michael:
If you want to stay with the original style 90-degree females, you won't find them except through an old parts supplier...they're vintage only. I have some if you want to go back into the brake light leg of the loom you can solder, heat shrink and re-wrap and make it look nice. If you want a pair, PM me your address and I'll send you a couple.
No 1961/66 has this type of switch, 1967 was the first year.
1961/66 switch either threads into the front of the master cylinder, or to a brass block that then threads into the master cylinder.
C1AZ-13480-A (replaced 0A-13480) .. Brake Lamp Switch (Motorcraft SW-24) / Available from Ford & autoparts stores.
Applications: 1940/66 myriad FoMoCo vehicles.
Kitty Chandler Carr
10-02-2016 12:18 PM
MY68F250
18
04-07-2008 03:08 PM
