Brake lights
Old Jul 13, 2009 | 08:37 PM
Raider50's Avatar
Raider50
Brake lights
Hi, I am very new to these older trucks(and doing my own work), and have a problem with my 66 that i just got. The blinkers light up the tail lights but, when i put on the brakes nothing. So where should i look on the truck to remedy this. Is there a switch on the brake peddle itself? is there something on the fire wall? Try and point me in the right direction. Thanks i appreciate the advice.
Old Jul 13, 2009 | 08:45 PM
camperspecial65's Avatar
camperspecial65
the brake light switch on these is on the master cylinder where 2 red wires slide on...many times they can get gummed up from nasty residue over umpteen years plus I have heard these switches have a tendacy to go bad although Ive never experienced that myself personally.
I believe there is a fuse also for the brake light as well in the fuse block on the firewall inside above the foot dimmer switch.
Sometimes, just pulling the wires off and on again can help the switch to give it a fresh point of contact.
- cs65
Old Jul 13, 2009 | 10:55 PM
inxquve's Avatar
inxquve
The pressure switch on the master cylinder is the most likely culprit. They're inexpensive and easy to replace. Make sure the connections are clean and tight.
I believe the turn signals and brake lights use the same fuse, so that shouldn't be the problem. If you find the pressure switch is not the problem, the brake lights do go through the turn signal switch. It's quite possible the connections in the t/s switch are worn or corroded.
Old Jul 13, 2009 | 11:15 PM
Raider50's Avatar
Raider50
alright that sounds like a great place to start, i will go look in the morning.Thanks ill report back in what ive found, hopefully it is as easy as it sounds
Old Jul 14, 2009 | 07:18 PM
Raider50's Avatar
Raider50
Update: Well i unpluged the 2 wires on the master cylender pulled them back in, put a crowbar on the peddle, ran to the back of the truck and poof i have brake lights. BUT i went to o'rilly to pick up some stuff, and i need both of the tail light covers and they cannot get them for me. So dose anyone know where i can the tail light covers?
Old Jul 14, 2009 | 07:22 PM
camperspecial65
which style of bed do you have ?? Theres 4 different ones depending on the year of your truck... and it all depends on the type of bed you have. let me know and I can look them up for you.
- cs65
Old Jul 14, 2009 | 07:29 PM
Raider50's Avatar
Raider50
It is a 66, with a 8ft style side(its not a step side, i forgot the proper name for it)? They are ovalish in shape
Old Jul 14, 2009 | 07:36 PM
camperspecial65
Ive got a pair for ya...not pristine, but good for a driver ...no cracks, chips etc...
- cs65
Old Jul 14, 2009 | 07:47 PM
Raider50's Avatar
Raider50
awesome, the only place i could even think to look was LMC truck, and im sure they wanted more for them than i wanted to pay. At this point in time i am more concerned about legal than perfect. LOL
Old Jul 14, 2009 | 07:52 PM
camperspecial65
you got mail...
- cs65
Old Jul 14, 2009 | 07:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Same taillight lenses:
1964/66 F100/250 2WD Styleside / 1966 F100 4WD Styleside / Some 1965/66 Econoline's (some have round lenses) / 1966 Bronco.
C4TZ13450D .. Right Side / Obsolete
KINSEL L/M in Beaumont TX has EIGHT = 800-816-2894.
C4TZ13451D .. Left Side / Obsolete
KINSEL L/M has SIX.
Dunno what Kinsel wants, I do know they do not mark the prices up.
The last MSRP for the right side was: $27.25. For the left side: $28.62
Old Jul 14, 2009 | 09:06 PM
Raider50's Avatar
Raider50
alright, thanks. That is awesome info. It gives me something to compare the other prices to.
