02 supercrew heater problem
Old 12-18-2014, 01:31 PM
krazykrenz's Avatar
krazykrenz
krazykrenz is offline
Marginal heat 5.4 f150 Supercrew. I have replaced the thermostat and flushed the heater core both ways till it ran clear (not much rust came out. I can hear the change in air flow so I know the blend door is moving.the hose coming from the front of the intake is very hot. the hose from the rear of the intake that comes from that small tube is not too hot. Which way does the coolant flow through the heater core?
Old 12-18-2014, 06:15 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
No you don't. Those are airflow diverter doors, not the temperature blend door.
From the hotter side to the cooler side.
You still have inadequate flow through the heater core due either to a restriction, air bubble, or a weak pump.
Old 12-29-2014, 02:29 PM
rickbrad's Avatar
rickbrad
rickbrad is offline
How can I tell if the temperature blend door is working on my 2002 F350?
Old 12-29-2014, 07:42 PM
projectSHO89
If you can control the temperature of the outlet air with the temperature control, the blend door is working properly.
Old 12-29-2014, 08:12 PM
rickbrad's Avatar
rickbrad
rickbrad is offline
My coolant overflow tank was dry and all my windows are fogging up when I turn the heater control **** into the red zone - so I'm pretty sure I need a heater core.
I am going to start searching, but if anyone knows of a good step by step guide to replacing a heater core, please reply or send me a PM.
Old 12-30-2014, 05:48 AM
JWA's Avatar
JWA
JWA is online now
Received 1,394 Likes on 1,103 Posts
There's more than a few YouTUbe videos about heater core replacement in the F-Series--give that a shot. Here's one to get you started:
thurston
1997-2006 Expedition & Navigator
11-26-2015 11:13 AM
racer87f
1997 - 2003 F150
01-04-2015 11:35 AM
yooper5.4
1999 to 2016 Super Duty
01-08-2014 12:03 PM
Baggins
Aerostar
17
02-19-2007 11:24 PM
bbwrench
1978 - 1996 Big Bronco
12-15-2005 11:37 PM
Quick Reply: 02 supercrew heater problem
