Gold heater core
Gold heater core
When did they start making heater cores out of GOLD ? On the way to home depot today the heater core started to leak . When I got home I pulled it out and went in to fire up the lap top and order a new core . After 58 years I think it could need replacing . Was I shocked at the price $178.00 . I think a radiator is only a few $ more . Sometimes I forget what money pits these old trucks are . What's next ?
Dave, where exactly is it leaking? Mine blew apart just barely a month after I got it back on the road. It had a crack where the hose met the tank. I got it fixed for $10 at a radiator shop here. If you can't find anybody down there to get it fixed, send it to me, and I'll show it to them.
Received 4,133 Likes
on
on
I had the core cleaned and checked about a year ago , and it was ok . I am thinking with the aluminum radiator and a higher pressure cap it just could not handle it . The fins bulged apart . I should have taken it to a shop to see what they could do , but I have a real bad cold or flue thing going on , and just didn't want to mess around . I have to get a cable operated valve to turn the heat on and off as , it is a pain to get out and shut off the heat valve under the hood when things warm up around 11 AM .
I heard that. Sometimes it's just easier to say "Dang the price, what's the terms!" and move on. Hope you get better soon.
When did they start making heater cores out of GOLD ? On the way to home depot today the heater core started to leak . When I got home I pulled it out and went in to fire up the lap top and order a new core . After 58 years I think it could need replacing . Was I shocked at the price $178.00.
I wasn't extremely thrilled about going this route, but I put in a generic Summit Racing heater. It is compact, fits in where the Magic Aire used to be, and has a 12V fan inside.
I did add a water control valve as a shut-off and I bought the kit that allowed me to hook up the defroster ducts.
I was skeptical at the start, but it came out looking pretty good. Here's the Summit part: http://www.summitracing.com/parts/su...01-1/overview/
Just a thought....this would be an easy way to cannibalize a 12V fan and a new heater core when restoring an original heater. Not a perfect fit, but not too bad.
Here's a pic:
I guess that makes it a dark-side heater!!
Dan
Here's a pic:
Dan
