New kid on block
Old 12-13-2014, 08:37 PM
1moses's Avatar
1moses
1moses is offline
New kid on block
I started searching for answers when stumped on a project for my dad and I found this forum. I consider myself somewhat mechanical for my era of building "muscle trucks" since the late 70's, but I may have met my match. A 1951 Ford F-2 Flatbed Flathead. I have convinced myself that he biggest problem I'm facing is a 6 volt pos ground. I've been working on a 1964 Ford 2000 tractor with a 6 volt system since I was a kid, but i am finding out this truck is a little different.A friend of my dad passed away and he bought his truck. It was running good for him and hauling hay on the farm 2 years ago. I have replaced naked wiring, starter, points, condenser, battery, plugs so far. It cranks as well as a 6 volt will but can't get points to spark. Looking forward to getting help from this group. Thanks
Old 12-13-2014, 08:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Welcome to the forum!
Have you checked the hot wire that goes from the points, under the points plate, to the coil? Not that you can eyeball it, it's hidden, but try an ohmmeter or continuity tester on it after disconnecting from the coil. It has to flex as the points plate rotates, it frays, then shorts out. You can replace it with the distributor in place but it's a lot easier to do with the distributor out.
PS have you checked for the rotor, rotating?
Old 12-13-2014, 09:09 PM
F-ONE's Avatar
F-ONE
F-ONE is offline
When you replaced the frayed wire, did you go back with the proper gauge? Six volt requires a big wire to carry the current. You can run six volt spec wire on a 12 volt system but you cannot run 12 volt sized wire on a six volt system. 12 volt spec wire is just too small. This is especially true for the battery cables. Six volt system battery and ground cables are massive compared to what you may be used to in those 70s Muscle ? Trucks.
The shop manual will tell you what gauge to use.
Old 12-13-2014, 09:26 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Welcome! I'll offer another possibility, the new capacitors are notorious for poor quality. Do yourself a favor and try the old one. Ross is spot on with his suggestion as well.
Old 12-14-2014, 11:16 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Welcome to FTE. We like Pic's
Here is how to post pic's on FTE
https://www.ford-trucks.com/forums/1...ure-guide.html
Old 12-14-2014, 09:34 PM
1moses's Avatar
1moses
1moses is offline
I did go back with 6 volt battery cables and 10-12 gauge on everything else.
Old 12-14-2014, 09:39 PM
1moses's Avatar
1moses
1moses is offline
I'll check the hot wire under the plate tomorrow and get back to everyone. Thanks for your help guys.
1moses
Old 12-14-2014, 11:00 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
They have their quirks and aren't for everyone, but the flatheads run so nice I can just stare and listen for hours. Welcome aboard.
Old 12-15-2014, 02:10 AM
F-ONE's Avatar
F-ONE
F-ONE is offline
I have fooled with vintage vehicles since I was a kid. Sometimes you just have to work on them. Go through the steps, go by the manual, abcd 1234. Check this clean that and waw-la...she fires up. You may never know why or why not, or exactly what you did to get it to run. Be patient check everything and she'll come around.
I will share a little secret. By far most electrical problems are ground faults, what was OK for decades can suddenly not be OK and needs checking/cleaning.
Then there is dead shorts, something grounding that should not be.
Then there is failed components, switches, coils condensors wires ect
Then there is mystery stuff like airing up a low tire, tightening the dome light or hooking up a tail light and boom, it cranks and purrs like a kitten.
If you are still fighting it with no luck, you may need to isolate the starting/ignition system with your own mini crank and run harness to eliminate any variables.
Good luck and keep at it.
Old 12-23-2014, 11:19 AM
1moses's Avatar
1moses
1moses is offline
1moses
Finally got a chance to piddle with this truck again. Using a test light, I have good power on switch side of resistor bar, but have very weak on coil side of bar and on that side of coil. I have absolutely nothing on distributor side of coil. Can I bypass old resistor? Thanks,
1moses
Old 12-23-2014, 11:39 AM
ALBUQ F-1's Avatar
ALBUQ F-1
A six volt coil doesn't need a ballast resistor.
Old 12-23-2014, 10:06 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
I once told a friend that if he could start my truck he could drive it... Key's were in my pocket but he kept hitting the starter button and it turn but didn't start for him... If I remember right the starter button always has power going to it but the ignition switch sends power to the coil... I'm I right guys?
Old 12-23-2014, 10:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yep, it leads to some exciting moments when kids are playing in the truck, too!
Old 12-24-2014, 10:07 AM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,841 Likes on 1,840 Posts
Welcome to the board!!
You've gotten some great advice here. While you can do tons of stuff with a test light they aren't so good at checking or shorts to ground. You'll need a meter to check if the wire under the points plate is rubbed through to the housing.
Good luck with it
Bobby
Old 12-26-2014, 12:24 AM
sere0501's Avatar
sere0501
sere0501 is offline
I didn't see you mentioning changing the wires. I'd double check the main wire from the coil/distributor cap. Also, that wire that Ross mentioned that you can't see the connection inside the distributor. I wonder if you can put one of these on your coil???
Jeff K
31
10-21-2013 02:49 PM
Reckedracing
1947 and Older Ford Trucks
01-08-2011 07:01 AM
wadar1969
19
12-14-2010 09:12 PM
123michigan
Electrical Systems/Wiring
06-02-2005 01:31 AM
kciv00
07-20-2003 12:34 AM
Quick Reply: New kid on block
