Vacuum Advance 101
Vacuum Advance 101
Winginit has just posted an excellent description of how vacuum advance works in this thread in the 335 Series forum. I think it is a good read and is helping me understand the situation.
I know I've read this before...
Wingingit is John Z from some Camaro board over a decade ago???
Timing & Vacuum Advance 101 - Team Camaro Tech
Otherwise, his post is pure cut & paste with no attribution.
Yes, I assumed that it wasn't written specifically for us. But the overall ideas should still apply. And while I'm not, at least yet, bought into the manifold side of the idle discussion, I am intrigued and want to explore it further. And, I'm old enough to remember that manifold vacuum was the stardard before emissions concerns came along. So, maybe there's something to it?
As for lost arts, I fear that distributor curving and carb tuning are both in that category. In fact, even the ability to find someone to rebuild a carb is waning. Makes me wonder about the wisdom of building project vehicles with carbs vs EFI. However, there may be no one to work on the current aftermarket EFI systems when the need arises later.
this is a great primer..
If we with Fords were to use the info it may be good to note that most vac canisters of our era are generally adjustable which is info that isn't widely expressed during the typical DS conversion.
Modern vac canisters are adjustable but afaik only for the total amount of advance with a given vacuum signal, but not when the advance comes in. Performance engines as the GM engineer notes have relatively low idle manifold vacuum and so care must be taken in the selection of the vacuum advance canister to prevent idle "fluttering" if manifold vacuum is utilized.
KRinAZ
18
08-29-2017 07:01 AM
Superred2
12-15-2010 11:43 AM
itzaford
09-04-2007 09:56 AM
DeathMobile
53
05-17-2003 10:15 AM
