69 f250 cmpr special
I've got a 69 f250 cmpr special with the 390 in it. It's got disc brakes in ftont and drum in the rear. When I step on the brake pedal it almost feels like no power brakes... It takes a good bit of leg power to push. The truck stops quite well for being a big ol beast. And I can't seem to get it to idle low enough. Don't have exact rpm numbers as I haven't installed the tach yet. But let's just say once it's warmed up I've got to keep the choke cable at least 1/4 of the way out to get it to idle low enough I can put it in gear (has the a.t. not manual) without feeling like I'm gonna do damage to the trans. And you can hear it's idling way too high in p/n. This is the first ford I've ever owned so any ideas/help is welcomed. Thanx in advance.
on
How to do the carb setting for the idle & air/fuel jets screws on the carb.
How to do a tune ups.
If "Idle is up to high back out the carb idle screw" at carb linkage.
A vacuum leak will also cause it to high idle also.
A bad Distributor vacuum hose or vacuum advance can cause a high idle.
orich
Original owners and shop manuals are available from faxonautolit.com (store located in Riverside CA .. open Monday/Saturday).
1964/72 Ford Truck Parts Catalog available on a C/D from hipoparts.com
In case you're unaware, dual piston caliper front disc brakes were an option for 1968/72 F250 2WD's and F350's. With front discs, the F250's rear drum brakes are 12" x 2 1/2."
Sounds to me that your brake booster is bad. 1st, brakes hard to push. 2nd,when the rubber diaphragm ruptures in it then it is a major vacuum leak. To test this theory take the booster's vacuum line back off and plug it. Start the engine. Idle will be a lot better. What usually ruins the booster is brake fluid seeping out of the back of the MC and in to it. Before buying a booster (if I am correct) leave the lines on the MC but gently remove it from the booster. Pull it just far enough forward where you can get your finger in the back of the MC to feel for fluid that's not supposed to be there. You may have to buy both.
O.k.... Update to the high idle vacuum leak... 1. Bad power brake booster check valve, 2. Bad pcv valve. Running much better now. Of course I had to completely reset to initial settings the high idle,the idle and the idle mixture screws and start over tuning the beast. But at least it finally runs right and the brakes don't take so much pressure on the pedal to stop! Thanx for all the comments and help.
wils3825
08-26-2016 07:13 AM
11-21-2014 05:04 PM
86ford185
05-15-2012 09:49 PM
80skeys
05-27-2010 10:06 PM
flyingasics
09-13-2006 01:30 AM
