Blown Sparkplug!
Blown Sparkplug!
Ok so here it goes, I am on my way to work today and POP! tsst, tsst, tsst. WTF is that, I stop and pop the hood and the noise is horrendous. Shut it down and a quick cell phone search later I find it to most likely be a blown plug. Limp it home and get to work. I have just been doing some research and I am freaking out. I am not sure of what plug it is yet as I have not had a chance to really check it out. But I have a few questions.
1. Does the sparkplug actually "blow" clear of the hole it is in with the coil?
2. What is the best "cheap" option, right before Christmas and I am a single income household-Thanks Obama.
3. I am mechanically inclined, can I do this at home in the driveway?
Sorry for the rant and thanks for any info as it will be a great help.
You need the correct type of insert installed, a new spark plug, and probably a new coil.
Do NOT let anyone install a helicoil or a Dorman repair insert, neither is likely to last and can cause worse damage if they fail.
Just look at the COPs for the one that's jumping around. That's our blown plug. Disconnect the fuel injector for that cylinder in the meantime.
Sorry to hear about your troubles, oh2sd.
This problem is caused by improper torquing of spark plugs and nothing else. Unfortunately for you whoever replaced the plugs last did it wrong, and that's why you're having this issue. You can get an OEM Motorcraft COP for around $50 online, or a cheap one from eBay for around $10.
