Steering Stabilizer Question
Is it normal for a stabilizer shock to leak oil? Reason I ask is I had a new Red Head Steering Gear and Stabilizer installed by my local shop about a month ago and it cured my steering tug-of-war issue right away. I've put about 800 miles on the truck since and all has been fantastic....until last night.
I went into a right hand turn and the damn thing felt like there was resistance, then it let go and turned, and after the turn I was playing tug of war with the wheel like a drunk driver (exactly like my intermittent problem previously). Problem went away after applying the brakes and turning the wheel back and forth. All of this was cured last month with the above fix until now.
Today I noticed oil drops on the ground and they are clearly coming from the stabilizer as I can see the drips coming out of it. Is this normal for a stabilizer or should I just pull the damn thing off? I pulled my old stabilizer off two months ago which seemed to cure the problem...but decided on the Red Head anyway, to which the tech claimed I really needed a stabilizer as well. He put a new one on instead of my old one as he said the old one was indeed bad.
Thoughts?
Thoughts?
A few years ago I changed the oil in my hydraulic system to Mobil-1 ATF. I jacked up the front wheels off the ground and had my wife run the steering wheel lock-to-lock several times while flushing the old oil out.
After I was through, I noticed a green fluid under the front end and thought it was coolant. The ol' taste-tester told me it was NOT glycol, but some kind of green oil!
My steering stabilizer (I believe it's a Gabriel) had puked at least a teaspoon during those repeated, quick lock-to-locks.
No evidence of any additional leakage since, however.
Pop
Pop
Many here recommended a stabilizer but after replacing the steering gear, right upper and lower ball joints, tie-rod ends, etc. the issue (wouldn't return to center at speed) is gone.
I have no stabilizer and from what I can tell, never did.
A stabilizer may help with other issues, just not the one I had.
My truck is an E99 bought it in 03 never had a steering stabilizer on it so I put one on didn't notice much smashed it on a rock many moons ago yanked it off and never put one on sense. You may have some front end issue if your fighting the wheel or have really skinny tires getting stuck in the road ruts.
Steering stabilizers came on the trucks with the 4x4 off road package. This also included the skid plates.
I added a bilstein to mine the wheel feels a little smoother, and takes out some of the negative feedback. It was very noticable on the road by my house.
