proud New owner need answers
hello all, New to the forum I just recently acquired a 1997 7.3 with 280,xxx on the clock and wanted to know a few things. it is a auto and has an old school no name 5 point tuner on it (4 tunes with high-idle) and its 4 wheel drive. the truck has had a LOT of owners at least 6 as far as I can tell with the receipts in the dash, seems to be a pretty well taken care of truck despite that. I'm 16 and basically driving my dream truck right now so that's pretty awesome but what I'm looking at with the truck and the picture in my head of what I want are preeeeetty different.the truck has a few problems notably it cuts out when you slow down to turn or stop if you tap the throttle at about 600 rpm it will idle down and sit just fine. also when I am at speed the speedo will cut out and the odometer will go blank then everything will go back to normal within a second, I don't think its a blown trans because it shifts fine and accelerates fine. I also have some other questions.
- what is the stock turbo size on this truck and at 280 will it need any work? (I have access to a '03 turbo with about 70k on it just saying)
- what is a really easy power number to hit with some light modifications? (I don't need a race truck I just want some power on tap)
- where/what are some good brands and websites to look for mods and replacement parts?
- what is HPOP?
thanks, anything else you think I should know just tell me I'm open to any and all information.
- what is HPOP?
Try searching the site for threads on diagnostics, for example, this thread gives you info of Forscan, a low cost tools that is effective "Forscan for Dummies" https://www.ford-trucks.com/forums/1...r-dummies.html.
You can also search for Diagnostic codes, obd2, or by engine symptoms. This way you learn from others. Site has a rich history of "symptom and cause". Read up on what's come before and eliminate the obvious.
For example, the wire harness on the 7.3 is vulnerable to damage where is crosses over the driver's side valve cover. Examine that location for cracked wires (due to heat mostly) and shorts that could be causing the engine symptoms you describe.
Focus on durability now. Stock 90cc injectors are not going to make much power, I think 220-240rwhp is about it. Forescan is highly recommended.
Get good air filtration on it. Most do that open Donaldson filter, I like my S&B box. Verify you have the master cylinder pressure switch update done. Invest in HD intake boot kit from Riffraff, OBOD are not your friends. Inspect battery cables and verify you have Group 65 size. Pick ip HD glow plug relay
Fluids front to back. Axle(s). Brake flush with new hoses, pull drums to inspect. Trans service, 4R100 pans have drain plugs. Coolant flush, add the SCAs or buy coolant with it in there.
Speedo issue is probably the PSOM needs to be rebuilt.
The following 2 users liked this post by Hit Man X:
TP38 and an 03 has a different mount that needs a different exhaust manifold, baby butt collector, cross T intake plenums and uppies.
Stock is great once all the boost leaks are gone, tuner will gain about 40+
Here and RiffRaff
- what is HPOP?
High Pressure Oil Pump that feeds the injectors in front of engine on top
thanks, anything else you think I should know just tell me I'm open to any and all information.[/QUOTE]
good read and welcome to the fun!!!
https://www.ford-trucks.com/forums/1...sel-truck.html
Here and RiffRaff
- what is HPOP?
Forscan is a PC program that uses a USB adapter or BT dongle.
Can use a tablet based on andriod or phone too like i do with a BT dongle
https://www.ford-trucks.com/forums/1...2-scanner.html
The following users liked this post:
When I was 19 or 20 with transmission problems and limited money, my best bet was a manual transmission swap.
it will only shift when I lift on acceleration, the fluid smells burnt, the speedometer is going wack sometimes working and sometimes. not it also bumps in and out of overdrive sometimes, when I have it up to speed consistently it will slip and the engine will rev over then it will catch and speed back up.
