transmission "grind" coming out of OD
so took my new-to-me '07 on my first road trip this weekend. all was well until i started playing with the cruise. turns out it works, but when accelerating on the freeway i notice the transmission makes a grinding sound, almost like i'm hitting a rumble strip for about half a second... more of a vibration i suppose. and it's only just before the transmission comes out of overdrive, never any other instance. i'm not sure on the age of the fluid.
ideas?
ideas?
If you take it to a good shop like O'neils in Cascade they will be able to hook up to it and tell you exactly what's going on. I think they charge like $80 for the diagnosis though. But they are the BEST in town. It could be as simple as a solenoid hanging up. It may even be able to be re-programmed to be fixed. Maybe the lot you bought it from will pay O'neils for a diagnosis?
This is the classic symptoms of torque converter shudder.
A drop & drain will change about half of the fluid. That should half fix the problem. Changing all of the fluid should fix all of the problem.
HERE is how I do it. This is written for the E4OD/4R100, but the procedure is the same for the 4R70W. The lines are not as easy to identify. One is on top of the other at the trans case. I don't remember which is which.
How do you add the new fluid? There is no suction in the cooler lines, it won't draw fluid out of a bucket.
i haven't put it in yet, so i don't have any results to report just yet.
