4x4 not engaging
4x4 not engaging
Looking at another Ex but the owner says the transfer case does not engage. Says it can be locked into 4X4 by crawling under it and engaging it manually by removing a motor [Servo motor ?] Does this mean I would need a new transfer case or just the servo motor ? I know mine did the same thing last winter. It would go into 4X4 and then pop out. Any help would be great.
Thanks Dave
Thanks Dave
on
Thanks Dave
Thanks Dave
Dang... mine worked fine when I checked out about a month ago. Now we have snow & cold and the hubs won't lock up and I can hear the tone of the defroster change when I turn the 4x4 ****.
Hopefully it's just the vacuum lines to the hubs, I have replacements to put on already... but I hate having stuff that doesn't work reliably.
Well that was the easiest 2 minute repair ever. The new PVH solenoid seems to have fixed it... the hubs lock almost immediately now.
Thanks for the advice! I had looked at the PVH before and it appeared to work but it was warm out then.
