Wondering what size travel trailers and fifth wheels you tow with your 7.3L?
#31
We tow a 38' 2014 Salem 29ud3 TT, 11,000lbs loaded, lots of mods to the truck. Tugly .. I would have to recommend against airbags after my adventure. My truck towed our new TT perfectly, except for squatting it. I installed a set of Firestone Ride Rites and can't keep the damn truck in my lane. Picture the leaf Springs attached to the frame, the weight is spread out over a three ft spread. Airbags take away the spread and try to carry the weight dead center of the springs. Which creates a teeter effect. Now this is just from my experience so Ymmv. I'm having a leaf added to my pack to support the heavy tongue weight. My Firestones will be on the market.
#32
#33
#34
Aerodynamics are as important as weight. A square-nosed 5er with a front living room (really tall) will eat you alive for fuel economy and control. Sacrificing a little height in a unit with a front bedroom (headboard up front, or shorter closet) will pay you dividends on the road.
Maybe it's just my truck, but if I hook any trailer with some weight to it I get around 10mpg. From a car trailer (loaded) to all of the work trailers I used to pull, to both campers I've owned.
If you're going to "full time it" I would focus on interior space over aerodynamics.
The nose of my unit is a HUGE closet. I live alone & my Jack Russell only has one fur coat, so I have plenty of closet space , but If your sharing that space with a woman, you'll need all you can get.
As for control, Yes it may make a difference, but I doubt enough to really feel it. I pulled my 5'r thru an incoming tropical storm a few years back. I was the only one on the road and honestly the wind was pushing me back and forth across three lanes of traffic, but is was a lateral push & there isn't anything you can do about that.
Honestly I've felt more "white knuckled" when being passed by semi's pulling my TT with my SRW F250. (didn't have a WD hitch)
I would have NEVER braved that storm pulling a TT, or with a SRW truck.
#37
#38
#40
Look into Air Lift 5000 series, easy to install and they mount Outside the frame. I put them on my truck when I bought it in 2007 and they have performed well since. Tug, I would stay away from the taller blocks and go with the bags only. Keep your truck level.
#44
E99 2WD with DP Tuner, Cold Air Intake, 6.0 Trans Cooler, Air Lift 5000 bags, Gauges.
I tow a 36WR Work and Play Toy Hauler. Although the trailer will gross at just over 14k I run about 12k and flirt with 20000 Gross. It's 36' long. My greatest improvement is the DP Tuner. Second would be the 6.0 Trans Cooler. I never run over 155 degrees even in 100 degree outside temp.
The E99's tend to be under powered. The DP's added transmission shift patterns are great. I usully tow iin 60HP. For downhill I use the decel tune. I had to upgrade my OEM hitch to a 16k. I use a 14K WDH and run two friction sway bars.
I am not in a hurry I usually run at 65mph...
6.0 Vs. Stock Trans Cooler
Cold Air Intake
Gauges With DP Tuner Switch
Cold Air Intake
