Wondering what size travel trailers and fifth wheels you tow with your 7.3L?
  #31
Old 11-13-2014, 01:23 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
We tow a 38' 2014 Salem 29ud3 TT, 11,000lbs loaded, lots of mods to the truck. Tugly .. I would have to recommend against airbags after my adventure. My truck towed our new TT perfectly, except for squatting it. I installed a set of Firestone Ride Rites and can't keep the damn truck in my lane. Picture the leaf Springs attached to the frame, the weight is spread out over a three ft spread. Airbags take away the spread and try to carry the weight dead center of the springs. Which creates a teeter effect. Now this is just from my experience so Ymmv. I'm having a leaf added to my pack to support the heavy tongue weight. My Firestones will be on the market.
  #32
Old 11-13-2014, 02:12 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Something ain't right, but I don't think it the air bags. Maybe the way they are installed or your sway bars on the hich. Never had a problem, always made it better. Make the truck ride better also.
  #33
Old 11-13-2014, 02:16 PM
Tugly's Avatar
Tugly
Tugly is offline
I'm picturing this in my head, and I can see where air bags make a terrible fulcrum for a TT. Anybody with a 5er is going to have the load centered right over the bags. It's a different beast.
  #34
Old 11-13-2014, 04:15 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Originally Posted by Tugly
Aerodynamics are as important as weight. A square-nosed 5er with a front living room (really tall) will eat you alive for fuel economy and control. Sacrificing a little height in a unit with a front bedroom (headboard up front, or shorter closet) will pay you dividends on the road.
Yes & no... While common sense would lead one to think that a more aerodynamic nose will improve economy, I haven't seen much of a change in MPG's from my 30' TT to this 36' 5'r.
Maybe it's just my truck, but if I hook any trailer with some weight to it I get around 10mpg. From a car trailer (loaded) to all of the work trailers I used to pull, to both campers I've owned.
If you're going to "full time it" I would focus on interior space over aerodynamics.
The nose of my unit is a HUGE closet. I live alone & my Jack Russell only has one fur coat, so I have plenty of closet space , but If your sharing that space with a woman, you'll need all you can get.
As for control, Yes it may make a difference, but I doubt enough to really feel it. I pulled my 5'r thru an incoming tropical storm a few years back. I was the only one on the road and honestly the wind was pushing me back and forth across three lanes of traffic, but is was a lateral push & there isn't anything you can do about that.
Honestly I've felt more "white knuckled" when being passed by semi's pulling my TT with my SRW F250. (didn't have a WD hitch)
I would have NEVER braved that storm pulling a TT, or with a SRW truck.
  #35
Old 11-13-2014, 05:44 PM
Gaugepro's Avatar
Gaugepro
Gaugepro is offline
I drag my TT from one end of the country to the other... Most times with the cruise set to 75-80mph... No issues with a proper weight hitch.
  #36
Old 11-13-2014, 05:47 PM
mecdac's Avatar
mecdac
mecdac is offline
Just a little guy, 4100 lbs soaking wet and aerodynamic. More importantly it meets my needs.
  #37
Old 11-13-2014, 05:49 PM
Gaugepro's Avatar
Gaugepro
Gaugepro is offline
Originally Posted by Jmatthews
32 bhds? I have the same camper I fulltime in, been to 35 states so far, now in Louisiana just left Co. Where it got down to -12 last night.
Yup... Been all over from Kansas to New Mexico, Washington to Cali, Colorado to Montana...
  #38
Old 11-13-2014, 06:45 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Yeah we've been from Florida to Connecticut to San Diego to Montana back down to Louisiana and places in between.
Going to Pa first of the year, be there a while.
  #39
Old 11-13-2014, 10:31 PM
Smokiesman's Avatar
Smokiesman
Smokiesman is offline
34 ft Coachmen ! Don't know the poundage but BigRed don't care he just hauls it!!
Smokie
  #40
Old 11-13-2014, 11:34 PM
puller45's Avatar
puller45
puller45 is offline
Look into Air Lift 5000 series, easy to install and they mount Outside the frame. I put them on my truck when I bought it in 2007 and they have performed well since. Tug, I would stay away from the taller blocks and go with the bags only. Keep your truck level.
  #41
Old 11-14-2014, 05:14 AM
Tugly's Avatar
Tugly
Tugly is offline
I've been watching Snowseeker's build, and I noticed those outside-the-frame air bags. I think that's the way to go.
  #42
Old 11-14-2014, 07:10 AM
Dan V's Avatar
Dan V
Dan V is offline
My Firestone Ride-Rites are outside the frame...2071 is the model I think.
  #43
Old 11-14-2014, 10:13 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
My 2006 33' Cougar.
  #44
Old 11-15-2014, 01:18 AM
1L243's Avatar
1L243
1L243 is offline
E99 2WD with DP Tuner, Cold Air Intake, 6.0 Trans Cooler, Air Lift 5000 bags, Gauges.
I tow a 36WR Work and Play Toy Hauler. Although the trailer will gross at just over 14k I run about 12k and flirt with 20000 Gross. It's 36' long. My greatest improvement is the DP Tuner. Second would be the 6.0 Trans Cooler. I never run over 155 degrees even in 100 degree outside temp.
The E99's tend to be under powered. The DP's added transmission shift patterns are great. I usully tow iin 60HP. For downhill I use the decel tune. I had to upgrade my OEM hitch to a 16k. I use a 14K WDH and run two friction sway bars.
I am not in a hurry I usually run at 65mph...
6.0 Vs. Stock Trans Cooler
Cold Air Intake
Gauges With DP Tuner Switch
  #45
Old 11-26-2014, 09:03 PM
sean23johnson's Avatar
sean23johnson
sean23johnson is offline
Bump!!
Mods, make this a sticky!! Love seeing the 7.3 at work! Plus I'm saving for a nice travel trailer
Quick Reply: Wondering what size travel trailers and fifth wheels you tow with your 7.3L?
