I want to thank
I want to thank
Id like like to give a forum thank you to Anthony (run6.0run), Julie (runswifey), and Corey (creator) for all the TLC put into my truck. I had originally went to SuperDutyService for headstuds and to diagnose some rough starts and shaky acceleration and we discovered 2 known bad injectors and one iffy injector and also low compression on cylinder 7. Some background info, about 2 years ago the egr cooler popped and the truck was hydrolocked for 2-3 months (truck had been parked for awhile and had been running and upon trying to move the truck discovered it was hydrolocked). The truck has been fine since until recently started having some rough starts, idling and shutter at lower speeds. Also had a headgasket leak. Anyway the hydrolock had caused a rust ring in the cylinder and a recess had wore at the top of the cylinder which we initially thought honing would take care of. No dice. Took .020 over but it cleaned up and got a full rebuild. Truck was tore down and put back together on a crazy fast schedule but Anthony and Julie, along with Corey got the job done. I highly recommend SuperDutyService for any of your 6.0 needs. Thanks again for everything and making my truck good as new.
FordTruckNoob
53
07-11-2019 05:49 PM
mongo75
01-07-2009 06:39 AM
