Power Steering
Power Steering
This is the style of power steering bracket I have on my 77 F250 4x4. When I look this part up, it should be for a 351. The reason for this post is, I am having a heck of a time trying to get the pulleys to line up. I don't want to brake belts or bearings so do I have the wrong setup? I have the old style hydraulic ram steering set-up. It doesn't leak, it works great, and I'm not trying to replace it. I just want my belt to line up and not stress the system. What have you guys done to modify/ fix this issue with a 460 in a highboy?
460 wasn't available with a M/T or 4WD until 1983.
D0AZ-3C511-F .. P/S Pump Support Bracket / Marked: D0AA-3C511-F / Obsolete
1973/79 F100/350 460 / 1970/71 Thunderbird 429 / 1970/72 Galaxie/LTD/Mercury Marquis/Torino/Montego 429.
D1AZ-3A732-A .. P/S Pump Adjusting Bracket-Use with steel reservoir pump / Obsolete
1971/77 F100/350 all V8 / 1970/73 Galaxie/LTD/Torino/Montego 351C/429 / 1971/73 Galaxie/LTD 400 / 1971/72 Thunderbird 429.
I seem to remember reading about this issue before, are you mounting the bracket flat to the block? I think you need some small spacers to hold the bracket off the block just a bit? See the red arrow?
Eye ball this L and L Products
And sorry no pic of that side of the engine of ol blue, so you have to wait till I get back home, than I will ck my set up. And post up some pics for you.
Spacers are in
There is a spacer at the water pump and the head. I like that one there though. They seem to have the rear spacer deleted by putting welded arm in it's place. My bracket is just at the wrong geometry. The pump is too low and out of line with the water pump pulley. The bracket I have seems to be the one for the newer steering, just minus the actual adjuster.
Has the front dipstick
OP put in the 460. It has the front dip stick so my best guess is it's a car motor. Emissions decal said 1976. No A/C, no frills. Old school power steering with the hydraulic ram. My best guess would be that the bracket is off the original 400 2V that came in the truck.
Rich, that would move the offset forward but I don't think that's a good idea. If you flip the pulley then you'll lose the ability to remove the pulley. The little hub with the groove that the pulley puller grabs will now be on the backside of the pulley.
