fuel tank
Old 11-09-2014, 12:40 PM
1slow5o's Avatar
1slow5o
1slow5o is offline
fuel tank
what fuel tank to use under bed of a 1968 swb f100? have heard you could use a tank a sender out of a 64 to 66 mustang or falcon. has any one ever done this? wold like to fill from inside the bed. thank you
Old 11-09-2014, 02:43 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 1slow5o
What fuel tank to use under bed of a 1968 swb f100?
Have heard you could use a tank sender out of a 65/68 Mustang, 1967/68 Cougar & 1964/65 Falcon? Has any one ever done this? Would like to fill from inside the bed.
1965/68 Mustang & 1967/68 Cougar have a 16 gallon tank (C5ZZ-9002-D), use the same fuel tank sender (C8ZZ-9275-C).
This sending unit was also used on 1964/65 Falcons, but the Falcon tank is different.
1969 & 1971/73 Mustang/Cougar have a 20 gallon tank. 1970 Mustang/Cougar have a 22 gallon tank.
All the fuel filler tubes are located at the rear of the tank.
Old 11-09-2014, 03:00 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Side fill? Do what TPDaniels did and use a tank spec'ed for a 72-80 International Scout...
https://www.ford-trucks.com/forums/1...l#post11249613
Old 11-09-2014, 03:02 PM
HIO Silver's Avatar
HIO Silver
All the fuel filler tubes are located at the [B]rear of the tank.[/B]
OP stated he wants a side-fill tank.
Old 11-09-2014, 03:06 PM
NumberDummy
Yes, I know that, but since he was asking about the Mustang fuel tank sending unit, I thought he'd like to know about the Mustang tanks...which are the most common tanks used for this conversion.
Old 11-09-2014, 08:13 PM
1slow5o's Avatar
1slow5o
1slow5o is offline
Think both of you for your help
smoky_diesel
04-27-2023 09:53 PM
Millam
03-26-2018 09:54 AM
timpage
27
08-10-2016 10:53 PM
johnmel59
09-30-2014 04:23 PM
FoMoCoPower
02-28-2009 09:48 PM
Quick Reply: fuel tank
