READ THIS!!! Wheel Alignments
If you have a truck or Expedition under warranty make sure you get a wheel alignment done prior to expiration. There is a caster/camber kit that must be installed to make these adjustments. It is not installed at the factory. I just had this done, and the total cost was $180. A standard alignment would have cost me about $48. I believe the kit installation was $30 per side and $60 for the kit. The work was done by an alignment shop. He told me Ford charges $30 more for the kit. It would cost you nothing under warranty, but the dealers and Ford do not inform you of the need for this kit. I was also told that the new Expy w/ IRS requires a kit for the rear as well. Be aware that if you have the alignment done at a dealer and your truck is within specs, they may not install the kit(s) or do an alignment (whether warranty or not).
basketcase
1983 - 2012 Ranger & B-Series
02-17-2017 04:27 AM
PKJ
09-29-2010 07:48 AM
