04 f150 fx4 cruise control not working
My 04 f150 fx4 has some cruise control issues. The cruise doesn't work at all and the self test doesn't do anything on my truck either. I tested the disengage switch which tested good but replaced it anyway for $21. I've checked all brake lights and replaced the 3rd light which was burned out. I've unplugged the brake switch and reconected in case of loose connection with no luck. I removed the brake switch and tested as follows (please correct me if my test method is flawed): top to bottom pins 1-6 for sake of this discussion. Pins 1 and 2 no continuity until brake button is pressed. Pins 3 and 4 are blank so no test performed. Pins 5 and 6 tested the same as 1 and 2 so am I correct in saying the switch is good? My truck will shift through all gears and back without ever applying the brakes. Bad shift interlock inside the shift console? I haven't torn into that yet but it's the only thing left I can think of. Is there any tests to be run on it with a multimeter? Thanks
Just to update, I have resolved this issue and it was the shift interlock in the console. I replaced it worth one out of the salvage yard and it worked fine. I opened it up to try and see how it works and found a transistor that looked burnt so I ordered a new one that I'm planning on soldering in to see if that would have been a workable fix. I'll post the results for anyone who might want to give it a try.
makuloco2000
1983 - 2012 Ranger & B-Series
03-29-2014 08:03 AM
schmidt89FX4
2004 - 2008 F150
19
09-21-2009 11:46 AM
